Gen I Body lift 2" question #592024 04/13/05 02:18 AM
Tycer Offline OP
Ive tried to do some searching on this forum and others and havent been able to come up with a good picture of how a 2" body lift is installed. Particularly, in the rear wheel well where there are a body mount bracket on each side. I have a 1989 Montero LWB and found a dead link on 4Crawler(Roger Brown) that I think would explain it all. Please excuse me if there are numerous posts on this because I have done searches. If there are, please link me to them. Thank you.
* * MY 1993 JEEP GRAND CHEROKEE * * RockKrawler Long Arm Lift, 8" of total Lift, Garvin Wilderness Rack, Hella Lights, 285/75r16 Firestone Destination tires.
Re: Gen I Body lift 2" question [Re: Tycer] #592025 04/13/05 03:05 AM
52degrees Offline
When my wife gets home from bible study, I will take pictures for you if you send me your email address.
They will be very large photos with lots of detail. I hope you have a broadband connection.
KG6VNX
Re: Gen I Body lift 2" question [Re: 52degrees] #592026 04/13/05 03:19 AM
87Montero Offline
Could you carbon-copy that to me as well Clay?
mccbre19@email.pct.edu if you can.. thank you <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Gen I Body lift 2" question [Re: Tycer] #592027 04/13/05 03:24 AM
Tycer Offline OP
Thanks so much ClayV. That will be awesome!!
TYCER1184@AOL.COM
Also, what brand of lift did you use? Any pointers?
Re: Gen I Body lift 2" question [Re: 87Montero] #592028 04/13/05 03:28 AM
52degrees Offline
You bet. More than happy to.
I really like my body lift. If the truck hadn't come with it I would never have done it. Now I know.
The only issues I have found is the fact that the bolts need to be tightened every now and then and the gasket for the floor shifter (manual trans/transfer case) needed to be removed and flipped over in order to keep it from tearing or stretching too much.
KG6VNX
Re: Gen I Body lift 2" question [Re: Tycer] #592029 04/13/05 06:03 AM
52degrees Offline
Ok, guys. Check your email. <img src="/forums/images/graemlins/smile.gif" alt="" />
KG6VNX
Re: Gen I Body lift 2" question [Re: 52degrees] #592030 04/13/05 04:54 PM
sparkem Offline
For fhe mounts in the rear wheel well, you can either get someone to weld an extention, or you could flip them upside down and grind out a notch to fit over the body lift and maybe a little for the bolt. I started doing mine but never finished. I am not telling you it is safe or unsafe to take out, I just dont worry about mine. If you get in that bad of a crash, I dont think they would help that much.
Re: Gen I Body lift 2" question [Re: Tycer] #592031 04/13/05 10:54 PM
L
lu0902 Offline
Can I get those pics too. I would really appreciate it. luisnew0902@yahoo.com <img src="/forums/images/graemlins/patriot.gif" alt="" />
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
Re: Gen I Body lift 2" question [Re: sparkem] #592032 04/14/05 03:00 AM
NHMonty Offline
why didnt I think of putting hte bolt in upside down! I just used the handy dandy BFH and beat the living crap out of the bolt to get it into the body. By far the rear is the hardest to get at seeing how you have to remove the lights and go into the body. Then I would place the front mounts second hardest.
1990 RS 4door 3.0L V6. 2 inch body lift. 33x12.50/r15 BFG AT's, 3 Superswampers(1 on the way) CD Player, Superwinch Hubs
My pics http://community.webshots.com/user/nhmonty
Re: Gen I Body lift 2" question [Re: NHMonty] #592033 04/14/05 04:48 AM
I can't believe the LWB is different than the SWB for that long bolt. I was able to put mine in right side up. You just can't drop it straight down in the way the OEM one would go in. You have to go into the big space behind the light, then feed it up first into the smaller space and drop it down into the hole from there. Sort of a zig-zag thing.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6404 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-06-22 14:00:35 UTC
