rear window squeek
#592437
04/14/05 09:42 PM
does anyone else have a rear window that sqeaks when you are driving. i can't figure out where its coming from and its driving me crazy!
Re: rear window squeek
#592438
04/14/05 10:43 PM
Little more info might be helpful
Starting with model, year, which side/complete rear, how often, how loud. Being less vague will get you more responses.
Nick
2000 XJ Classic - Classically a POS 1994 Isuzu Amigo XS -Sold 1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
#592439
04/15/05 12:06 AM
Yeah, I have that problem sometimes... Wrap a little ducktape around the U shaped latch, wrap it 3 or 4 times... I usually have to replace the tape every 6 months or so... I know this is just a temp fix, but it works for me <img src="/forums/images/graemlins/notooth.gif" alt="" /> ![[Linked Image]](http://img232.echo.cx/img232/8697/cimg00075vr.jpg)
'93 Rodeo - Dana 60 FF Rear - Dana 44 Front - 35's
[Re: Ride Hard]
#592440
04/15/05 01:48 PM
this solved my problem!!!! thank you! it was the most annoying noise ever! Yeah, I have that problem sometimes... Wrap a little ducktape around the U shaped latch, wrap it 3 or 4 times... I usually have to replace the tape every 6 months or so... I know this is just a temp fix, but it works for me <img src="/forums/images/graemlins/notooth.gif" alt="" />
#592441
04/19/05 11:37 PM
Glad to hear it helped! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Ride Hard]
#592442
04/20/05 12:39 AM
A thin coat of the thick lithium grease (peanut-butter consistancy) might help, too.
#592443
04/25/05 05:55 AM
I have been having the same problem with my back window in my 99 Rodeo as well. Thanks for the great tip about the duct tape. Im gonna try it.
[Re: Wayne]
#592444
04/25/05 05:55 PM
Like Wayne said, the White Lithium grease solves this problem too. I had the same issue a few years ago and sprayed it twice. The first squirt lasted about 6 months and the second spray has lasted me about 3 years and still no squeak. I'd be afraid duct tape would fray at some point and bind up the window keeping it shut or gumming up the lock and not locking shut at all....
Since both approaches work, it's your choice.
[Re: Michelle]
#592445
04/25/05 05:57 PM
The latch inside of the rear is plastic. What's happening is the plastic is wearing over time and allowing it to move just enough to sqeek and rattle. That kind of stuff drives me nuts as well. I used electrical tape with the same results. Athough I need to replace it as it's starting to rattle again.
Joe
