1995 Sportage (compression??)
#594501
04/19/05 09:22 PM
My Sportage is a 2.0 Liter SOHC. It is misfiring. I did a compression test and found the back two cylinders low & very low ! It doesn't use much oil so I'm wandering if these motors have any common problems ?(blow head gaskets, bad valves??) Maybe it's possible the seals on the injectors could be leaking bad enough to loose compresion ?Anybody have any suggestions?
Thanks, Dondobe
Re: 1995 Sportage (compression??)
[Re: Dondobe]
#594502
04/21/05 04:13 AM
Found my problem !! Someone tried to adjust the valves & adjusted them out of order.(leaving three exhaust valves too tight, which left them open not allowing compression to build !!! It's like a new ride !! Dondobe
[Re: Dondobe]
#594503
04/21/05 11:42 AM
Kia Moderator Emeritus
Glad you found your problem. I didn't know that the SOHC engine had valve lash adjustments. The DOHC engine doesn't.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5893 MB (Peak: 0.6426 MB) Data Comp: Off Server Time: 2026-06-20 02:45:27 UTCValid HTML 5 and Valid CSS
