EGR Hex Bolt? #595361 04/22/05 05:41 AM
mr_spicoli Offline OP
I cleaned the EGR tube the other day and was looking at better way to really clean it thoroughly so I don't need to do so frequently. I noticed there is a hex bolt just below the EGR which seems to plug the end of the EGR tube. I figured I could remove this to gain better access to the tube, but it's stuck. Initially, I was able to move it just a bit but now it's stuck. I've tried when it's been cold and hot to no avail. Any ideas? Is this a reverse threaded bolt?
Any help is appreciated.
For those who wonder why I would need to do this, I talked to an Isuzu mechanic when waiting for an IMG replacement and he said they use some a wire or coat hanger to stick through the butterfly valve and ream out the EGR tube. Then spray the throttle body cleaner and finish with compressed air. I have done this and it seems to work fairly well but I think that it work better if I had access to the tube from the EGR side.
2000 Rodeo LSE
Re: EGR Hex Bolt? [Re: mr_spicoli] #595362 04/22/05 06:09 AM
muskyamigo Offline
The bolt on the under side of the EGR holding the tube to the valve is a 22mm bolt with a normal thread. just remember you're looking at it from the back of the bolt.
BTW its good to see other Minnesotans on here!
Mike W
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5873 MB (Peak: 0.6359 MB) Data Comp: Off Server Time: 2026-06-04 08:29:14 UTC
