Fuel Filter Location?
#595624
04/23/05 12:35 AM
I need to know the location of the fuel filter on a 95 XJ. I am thinking that it is in the tank, however, There is one inline just forward of the tank.
Just wanting to make sure that if I am real lucky, all I will have to do is replace the inline unit.
Thanks for your help
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: Fuel Filter Location?
[Re: fishtaker]
#595625
04/23/05 01:27 AM
Mine is just forward of the tank and although the pump in the tank has a strainer it doesn't have an actual filter. if its like mine its a snap to change. Just pull the relay for the fuel pump, turn her over a few times, and your good to go. Your lucky day. <img src="/forums/images/graemlins/kewl.gif" alt="" />
#595626
04/23/05 01:37 AM
Thanks for the help. Just one more questions. What fuse controls the pump?
[color:"red"]I KNOW I SHOUOLD GET A CHILTON'S [/color] , but it is a friend of my son that owns the truck.
[Re: fishtaker]
#595627
04/23/05 01:39 AM
it should tell you on the inside of the cover for the power distribution block under the hood. the relay will be a square black lookin thing.
#595628
04/23/05 01:42 AM
[Re: fishtaker]
#595629
04/23/05 02:28 AM
I forgot one verry important step. Got the relay pulled, ran it till it died, all is OK. Crawl under the jeep and loosen the filter, gas shoots all over the place. I forgot to vent the fuel tank!!!
Thanks again for the help
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6700 MB) Data Comp: Off Server Time: 2026-06-09 19:19:29 UTCValid HTML 5 and Valid CSS
