Chevy spring swap- I need to vent..... #596809 04/26/05 04:19 AM
TexJeff87 Offline OP
Did the swap today. Very frustrated. <img src="/forums/images/graemlins/frown.gif" alt="" /> It'sitting about 3 inches lower in the rear now...looks like I'm driving a pre-runner. My headlights are pointed up. My rear shocks are now too long. The spring is only a half inch from the stock hanger. "Torch it off" you'll say. Well, dammit, I'm outa oxygen, plus the friggin' gas tank is RIGHT THERE. Sure, I can put in an AAL, but that means taking the whole thing apart again.
How did those of you deal who've done it deal with this stuff? I researched it, read the PBB FAQ over and over, got the right parts...I guess what gets me the most is that you can never do a mod or fix a problem without causing another one.
OK, vent/rant over.
Jeff
If Mad Max had a 4runner...
Re: Chevy spring swap- I need to vent..... [Re: TexJeff87] #596810 04/26/05 04:25 AM
Adam F Offline
I don't understand what you mean by that. You did move your stock front hanger back 11" right? What shackle setup are you using? How many leafs are in the pack? How much lift did you end up with?
97 4R, stock, daily driver
Re: Chevy spring swap- I need to vent..... [Re: Adam F] #596811 04/26/05 04:31 AM
the new hanger (budbuilt) is 11 inches forward. It's a 3 leaf pack with an overload. I have a 9.5" eye to eye shackle in the stock hanger.
What I should have said is that the spring clamp is a half inch from the stock spring hanger. As in, half inch below. Any uptravel and it hits.
Re: Chevy spring swap- I need to vent..... [Re: TexJeff87] #596812 04/26/05 04:34 AM
Dok Offline
Just bend it open more, that seems to be the popular thing to do for people that don't torch it off. Shackle sounds like it might be a problem too, most of 'em I've seen either use a double shackle bolted to the stock location or a new shackle mount that's moved back.
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: Chevy spring swap- I need to vent..... [Re: Dok] #596813 04/26/05 04:38 AM
About the shackle...I did a poll on PBB. There are more guys running a long shackle in the stock hanger than anything else. That's why I went that way.
I already took off the rear spring clamp. Prolly do the front ones too and put on an aftermarket clamp in a different spot.
Re: Chevy spring swap- I need to vent..... [Re: TexJeff87] #596814 04/26/05 04:41 AM
I gotta go to bed. I'm beat. But I know that you all are so awesome and everything, that when I get up in the morning all my problems will be solved. I've got faith in ya'!!! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Chevy spring swap- I need to vent..... [Re: TexJeff87] #596815 04/26/05 10:08 AM
Snowtoy Offline
Were you running lift blocks with the stock springs? If so, you need them with the chevy swap. In my experience, the chevy springs don't provide any lift, only more wheel travel and generally a softer ride.
Re: Chevy spring swap- I need to vent..... [Re: Snowtoy] #596816 04/26/05 12:14 PM
ChrisH Offline
I ended up getting about 2"-2.5" out of my chevy leaf swap. My stock hangers are definetely in the way too, I plan on taking the cutoff wheel to them when I get the chance. I have an 89 so my spring hangers are different, but I put mine ezzactly 9.5" forward, center-to-center.
My shackle... I'm running the double shackle setup, a set of Roger Brown's (4crawler) extended shackles,+2", that're 5.5" hole center-to-center if i remember correctly. Then the Stock chebby's attached. Stock rear hangers.
My rim to fender is about 19.5" I think, I've got a 3" bl.
What did you have in before?
*Clank Clank Goes my flex hehe*
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: Chevy spring swap- I need to vent..... [Re: ChrisH] #596817 04/26/05 12:18 PM
Snowtoy, I left the two inch blocks in.
Chris, I dinna have a BL, and I'm with you on the cutoff wheel.
I guess I'm a little lucky in that my front shocks are a little short...I'm gonna swap 'em out, front to back and back to front.
Re: Chevy spring swap- I need to vent..... [Re: TexJeff87] #596818 04/26/05 01:59 PM
missouriman Offline
we need pictures. I am getting ready to go chevies also.
maybe I should go with 2 or 3 inch lift chevies?
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6358 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-11-02 01:23:59 UTC
