Page 3 of 4 1 2 3 4
Re: Trooper MUA5 Oil situation [Re: Frisky] #597376 05/03/05 08:48 PM
mlclark Offline
Isuzu Moderator
Yup, it is a flanged seal that installs from the outside.
Michael
Re: Trooper MUA5 Oil situation [Re: mlclark] #597377 05/03/05 09:28 PM
Bigpoppax2 Offline
If you are talking about the front input seal yes it's easy enough to change. Just pull the tranny and take the clutch fork off. Then the front cover needs to come off of the inside of the bellhousing. There should be about 5 or 6 12mm bolts holding the cover on. Now on the inside of the front cover is the seal that needs replaced. My seal looked pretty good, it was the front cover that needed re-blue-glued. It seems as if the cover itself was actually what was leaking.
Joe
Re: Trooper MUA5 Oil situation [Re: Bigpoppax2] #597378 05/03/05 10:11 PM
mlclark Offline
Isuzu Moderator
Joe, I am really scratching my head here. I could *swear* the front output seal is installed from the outside of the case (i.e. you don't have to crack the case to replace it), but it has been a few years since I have had to mess with it.
As far as resealing the case, for anyone reading, throw away that awful blue silicone sealant. It is made by the devil. I am a reformed blue goo user and I have been blue goo free for several years. Get the grey, it is much better, it sticks better and it does not have quite the tendency to squeeze out and then peel off and then cause havoc in other locations.
Good Luck,
Michael
Re: Trooper MUA5 Oil situation [Re: mlclark] #597379 05/03/05 10:45 PM
randii Offline
Better yet, read the specs and use the right goo.... there are form-in-place, cure-in-place, and anaerobic gasketing compounds and gasket-dressing agents as well as bonding, threadlocking, and threadsealing unguents.
Read these:
http://www.mad-ducati.com/Articles/GasketSealant.html
http://www.asashop.org/autoinc/jan97/gasket.htm
Bookmark these:
http://www.loctite.com/int_henkel/l...h=Assembly%20Products&pathid=OEM
http://www.mgchemicals.com/products/silicones/appguide/auto_app.html
http://www.permatex.com/selector_chart/selector_chart.asp
Remember, more isn't always better.
Sincerley, a reformed user of silicon blued goo, but inveterate recidivist Hylomar dabber,
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Trooper MUA5 Oil situation [Re: randii] #597380 05/03/05 11:02 PM
mlclark Offline
Isuzu Moderator
Save the innane trivia links for after Moab.
I would suggest you become "one who is out in the shop making your truck run." Now. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Trooper MUA5 Oil situation [Re: mlclark] #597381 05/03/05 11:18 PM
randii Offline
Wish I could di it NOW, but I'm at work. <img src="/forums/images/graemlins/frown.gif" alt="" /> Worse still, I have interviews tonight at 7, 8, and 9 pm...
Randii (who may actually doing job interviews from under his truck)
Re: Trooper MUA5 Oil situation [Re: randii] #597382 05/03/05 11:34 PM
mlclark Offline
Isuzu Moderator
Well...at least some kind of work is getting done in the proximity of Uzi. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Trooper MUA5 Oil situation [Re: mlclark] #597383 05/04/05 04:19 AM
F
Frisky Offline OP
OK guys, now you are threadjacking and getting off topic here. Save the playful MOAB banter for the other thread <img src="/forums/images/graemlins/shame.gif" alt="" />
The seal I am talking about is on the front of the tcase, not the tranny. I think that just pulling the driveshaft (front one) should allow me access to that seal. As for the blue/gray/red/orange/purple goo, I guess I will have to figure that out when I get there.
Any other input is appreciated from those experienced. And thanks for the info so far
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: Trooper MUA5 Oil situation [Re: Frisky] #597384 05/04/05 04:33 AM
onebadtrooper Offline
yeah. its easy to get to. If that is where its leaking, then maybe we can both do them at the same time. I have to do the same thing. I had the front output out when I did my 3.07's. It realy is pretty easy. I had to heat up one of my front drive shaft bolts to get it loose. Thats when I think I fried it. You just unbolt the drive shaft, take out the nut, take off the flange, take out the bad seal. Then replace the seal, and repeat steps in reverse. And here's a <img src="/forums/images/graemlins/kewl.gif" alt="" /> for the <img src="/forums/images/graemlins/baby.gif" alt="" />.
Re: Trooper MUA5 Oil situation [Re: onebadtrooper] #597385 05/04/05 02:01 PM
F
Frisky Offline OP
So is this seal a dealer part, or can I get one at a local parts house???? I am almost sure that is where it is leaking from, but when I am on the road, it get's oil everywhere, so it is hard to tell.
I figure it can't hurt to change it anyway, and if it still leaks, I will deal with the only other place it can be leaking from.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6429 MB (Peak: 0.7539 MB) Data Comp: Off Server Time: 2026-07-14 21:46:54 UTC
