Rear spring hanger dimension question - leaf swap #597390 04/27/05 06:33 PM
E
extremesolo Offline OP
I am swapping in 63" chevys and I had a friend make the spring hangers for me. He layed the pattern out flat and then cut and bent the hangers. The problem is I need a 3" inside dimension and he bent them as narrow as he could and they are 3.5" inside. Should I go buy new hangers or will I still be okay if i buy long enough bolts and use some washers or other material to take up the extra .5" of space? Will there be too much play for it to work properly? Thanks.
1987 4Runner - 22RE, 290,000 miles 63" chevys, double shackle, BJ spacers, downey IFS truss, extended differential breathers, 33x10.50 BFG MT's. Soon to come - aussie locker in rear
Re: Rear spring hanger dimension question - leaf swap [Re: extremesolo] #597391 04/28/05 10:39 PM
TheBandit Offline
Make the hangers out of 1/4" thick 3.5" box tubing. That will give you the correct 3" inside dimension and the hanger will be beefy
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5867 MB (Peak: 0.6347 MB) Data Comp: Off Server Time: 2026-06-22 05:05:44 UTC
