Alignment & Camber Adjustment, Where in MN?
#597469
04/27/05 10:41 PM
I have called a few places in the Mpls area and I get the same answer in regards to adjusting the camber after cranking the torsion barsàöcanÆt do it, need to go to a specialty shopö. The first guy said that it depends on the vehicle, but then I said that I was going to crank the torsion bars and said they would not have the ability to adjust the camber with that type of modification.
BTW IÆm only cranking them 2ö max and installing Trooper coils in the rear. I have cranked the TBÆs in the past (<1.5ö) and there is a very noticeable difference in the camber \==/. Does anyone know of a place in Mpls/St. Paul that wouldnÆt have a problem adjusting camber after a TB crank?
I know IÆve read on here that Sears was able to do it, but that is one of the places I called that said they couldnÆt.
Thanks.
2000 Rodeo LSE
Re: Alignment & Camber Adjustment, Where in MN?
[Re: mr_spicoli]
#597470
05/01/05 12:39 AM
I've taken my lifted vehicles to Hoover Alignment in Minneapolis. I've always had good luck with them. The only time they couldn't do anything to my truck was when they ran out of gas for their torches and couldn't get my tierod loose, but they didn't charge me so, I just took it back later.
I think there's a Hoover in St Louis Park as well,not sure though.
-Mike W
Mike Walter '98 Amigo well used '94 Rodeo in need of help '99 Ram CTD for hauling feather pillows '01 unheated shop
PHP: 7.4.33 Page Time: 0.360s Queries: 15 (0.003s) Memory: 0.5879 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-06-17 02:20:32 UTCValid HTML 5 and Valid CSS
