Re: Just a thought [Re: tomriddle] #597481 05/01/05 10:54 PM
On stock flat springs ONLY when you are flexing the spring hard the tires move backwards away from the obsticle becuase of how the shackel works. So if you flip the shackle to the other side, the tires is instead pushed into the obsticle. If you have heavyily arched springs that won't flaten out or go past flat, then there is no need for a reversal.
Re: Just a thought #597482 05/02/05 02:26 PM
A shackle reversal is also supposed to improve handling with less wander. I have no handling problems with my jeep because my springs are too stiff, but all of the ads claim better street manners. I have also read that brake dive can be an issue with SRS, but these are Jeeps not race cars so that doesn't bother me. I also like the Full traction kit beause it will give me a little more lift.
Re: Just a thought #597483 05/02/05 07:31 PM
F
Fred Blackstone Offline
For rockcrawling, the shackle reversal is a good idea, at least in my opinion. My 2&1/2" Alcans are somewhat flat on the SOA YJ. The shackle reversal eliminates the long, hanging shackle on the front of the spring allowing more approach angle to avoid smashing into vertically flat rocks. Very few things are as jolting as hitting a vertically flat rock you're attempting to climb over. The Alcans actually move backward somewhat as the tires grip the rock, but it is hardly noticeable. I also have a boomarang shackle on the rear of the leaf springs, it appears to be an improvement over the straight shackle. But, I did have to invent a limiting stop to prevent the leaf spring bundle from bending into a bobby-pin shape for rare climbing situations when the front end is up on the rock and wants to bounce. I also have a limiting stop to keep the tire from rubbing in the rear of the wheelwell, this seems to be mostly a problem descending steep trails that have rock obstacles and/or deep holes.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5920 MB (Peak: 0.6449 MB) Data Comp: Off Server Time: 2026-06-23 08:20:05 UTC
