Re: 4.3 V6 Raider/Montero/Pajero club?
[Re: BobShaw]
#598313
05/02/05 04:46 PM
Painless wiring has come up with transplant harnesses for many motors including the 4.3L in its many forms. It uses the stock ECU and if you want to use the newer Vats ECUs with your Vortec, they have a Vats diable module. Plug and play. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: BobShaw]
#598315
05/02/05 05:50 PM
Add me to the Club.
Mudflap
#598316
05/02/05 07:14 PM
If you put a GM engine, you have a few tranny options and t case options available. Sure you could get custom adapters for the mitsu engine, but it would cost you out the ***.
[Re: sparkem]
#598317
05/03/05 01:43 AM
Lets play water pump goes out scenario.... Mine costs 13 dollars, and can be fixed with a 9/16ths wrench in about 30 minutes.
3.5? hahah not.
I'll replace 10 water pumps, and be happy about it.
How about a total rebuild? ouch on that 3.5.... better off getting some used 90k one, and selling your truck.
I better go get my butterfly valve recall fixed.. ohh nevermind...... this motor does not have the self destruct recalls in effect...IE crank bolt, and butterfly valve
For ME, it was about Performance and longevity for the $.
I could have put a vortec 350 in there(which will be next). same deal there. cheap, and easy to maintain.
[Re: Scottie2113]
#598318
05/03/05 04:38 AM
My 4.3 has nothing whatsoever to do with reliabilty, durability, or whatever. It is because I now have gearing options.....and in fact already have a 4:1 low range transfer case, with twin stick, 4.88 diff gears, and an 800 rpm stall torque converter! <img src="/forums/images/graemlins/smile.gif" alt="" /> Try doing THAT with a Mitsu set-up! Not gonna happen. Of course mine will never see the streets again.....but I prefer it that way! <img src="/forums/images/graemlins/smile.gif" alt="" />
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
[Re: lee_raider]
#598319
05/03/05 04:53 AM
Glad to hear it Lee.  We need some pictures!!! How about that 800rpm stall converter?? thats like stockish. ?? whats up with that?
[Re: LandRaider]
#598320
05/03/05 07:39 AM
For anyone interested, I still have the tranny-transfer setup out of my late 4.3 Gen1:
Borg Warner T5 gearbox, mated to a Mitsu transfer case out of a 1989 2.5TD (auto). Gearbox is bolt-on for the right Chevy bell-housing (S10). Bolts staright onto Misu cross-member.
Make me an offer, remember shipping is from South Africa.
Damn, I miss that 4.3!
1989 Exceed LWB 4m41 (3.2DiD TurboDiesel 5-spd Manual Tranny 2" lift 31" BFG A/T
[Re: LandRaider]
#598321
05/03/05 01:32 PM
A stock TH350 converter is about a 1500 rpm stall, I went with a lower one. Now I'll need to do some brake work too.
[Re: lee_raider]
#598322
05/03/05 02:56 PM
Lee that sounds bada**. We need some pics.
