Page 3 of 3 1 2 3
Here's my problem... [Re: Houston] #599064 03/07/07 07:21 AM
How can I check if my AC system is ok and can accept either refrigerant safely and w/out leaking everything out?
Is there a way to pressure check it before I throw in the R12/134?
Also can this be done by anyone or are special tools and/or training needed first?
TIA
Re: Here's my problem... [Re: off-roader] #599065 03/07/07 09:20 AM
The right way to inspect a system, as I understand it, is to extract the old refrigerant under vacuum (it is stored, not vented off), add a dye and fill the system back up. While operating the a/c, the tech looks for dye leaking out as well as having a tester/sniffer device that can detect smaller or harder to see areas of lines/connections, etc. If it leaks it should be repaired. If the system has to be opened for repair or for any other reason, there are always parts that should be replaced. A/C repair is not cheap, but consider this: reputable shops would love to extract your R-12, assuming there's any in there, and they should buy it off you if you're switching the system to R-134a. This can work to advantage, obviously, if you can find a shop that does it. I'm afraid too much of it still gets vented to the atmosphere and either doesn't get recycled or the customer is unaware of its value and doesn't get any credit for it.
R-134a is available at auto parts stores, along with cheap hose and gauge sets. Their effectiveness is limited, however, as a single indicator is only going to tell you the low side pressure, and not give you any information (or little info.) about what's happening on the high pressure side.
Improper use or careless handling of refrigerant can be harmful or fatal, folks. Accidental discharge of high pressure refrigerants can, for example, freeze your eyes, causing irreversible damage (blindness). Freon/R-12 (I have read) burns with an invisible flame, which does not sound fun. In the day, I could buy a can of freon for well under $1 and add one to my car every day, if I had to - - if it leaked, no big deal. These days, I'd say to have it professionally worked on so as to not throw away a lot of money, or damage something valuable because you don't have the tools, equipment and training to do the job right.
I really like this site "How Stuff Works." They didn't have anything I could find on automotive a/c, but this article covers the basics:
A/C Basics
Please, if anyone notices incorrect info in my post, feel free to fire away; I deal in floorcovering materials for a living...
Re: Here's my problem... [Re: off-roader] #599066 03/07/07 03:52 PM
52degrees Offline
I have most of the tools and training to do that for you, however, with the price of fuel right now, it might be less expensive to stay on that side of the hill and pay a shop to do it.
You can usually find a shop to do an a/c service for less than $50.
KG6VNX
Re: Here's my problem... [Re: 52degrees] #599067 03/07/07 08:50 PM
By "service" do you mean do you mean inspect the system for leaks then refill it with R134 and replace any necessary O-rings or do you mean inspect and refill w/ r12?
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 4.005s Queries: 16 (0.005s) Memory: 0.6131 MB (Peak: 0.7030 MB) Data Comp: Off Server Time: 2026-06-05 22:18:12 UTC
