electric locker???? #601067 05/08/05 02:50 AM
OK so my Rodeo finally runs.... No idea why, it just came back to life by itself.
So I'm looking into improving its off-road capabilities. Can't say I'm a hard-core off-roader, I just want to be able to drive up to my fishing holes and have a little fun. I'm looking into rear locker... electric locker to be more specific. Any comments on em? Any model even available for my 91 Rodeo?
I think I'll make that my first real off-roading mod.
Thanks for the info!
Re: electric locker???? #601068 05/08/05 03:40 AM
I've done a little research on the Detroit electrac and it seems like a better deal than an ARB because when unlocked it still works as a posi unit. The ARB is just an open Diff. Now that said IF you have much snow and ice in the winters you want the ARB 'cause that open diff in 4wd front and rear will help you stay in a straight line 'cause only one wheel is spining at each axle. Even a posi can get pretty squirly on slick snow or ice. I'm sure a lot of people will disagree and say "the more traction the beter" but I have first hand driven a 2wd open diff truck on ice better than the cherokee in front of me that had a rear posi, he was all over the road. You may want to check on the OX locker too. I like the simplicity of a cable accutuated locker. Mechanical is almost always better than electric or air in the enviornment we put our trucks through.
Re: electric locker???? #601069 05/08/05 04:11 AM
coming from Quebec and having to drive through over a foot of snow to get to work sometimes, I know exactly what you mean and that is exactly why I want to be able to unlock it when I don't need it.
I am a car enthusiast but quite a newb. to the world of off-road mods. Do you have any model to recomend? mechanical locking seems like the way to go. I was also considering a LSD for the front.
Thanks for imput!
Re: electric locker???? #601070 05/08/05 05:25 AM
Jim_Paget Offline
Since you have a '91 Rodeo, you have the GM 10-bolt rear end, unless somehow the Canadian ones are different than in the US.
The OX locker is only available for AMC 20, Dana 30, 35, 44 and 60.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: electric locker???? [Re: Jim_Paget] #601071 05/08/05 06:26 AM
That sounds about right... Any other option?? cable or electric.
Re: electric locker???? #601072 05/08/05 06:38 AM
strawmyers Offline
Isuzu Moderator
Swapping in a D44 from a later Rodeo would probably be a viable option. Never looked into it, but surely it would be pretty much a direct bolt-in. Might be worth some research... open up your aftermarket options for sure. Just get one with matching gear ratios to your current axle.
Sean Strawmyer
Re: electric locker???? [Re: strawmyers] #601073 05/08/05 06:44 AM
would be an option but I'm trying to avoid going that route... I want to keep it as simple as I can for now.
Re: electric locker???? #601074 05/08/05 12:09 PM
Jim_Paget Offline
Matt Goldsohn made that swap in order to go from 4.30 gears to 4.56 (which also means swapping the front R&P). You do gain disk brakes all around by doing the swap. I don't remember the details, but some changes are necessary for the emergency brake cable.
Jim Paget
www.rrr4x4.com
Re: electric locker???? [Re: Jim_Paget] #601075 05/09/05 02:42 AM
if you have the gm 10bolt then you would probably be better off if you just throw in an ARB cause for about $1000 (parts and installation) you will pay less than buying a d44+new gears+cable locker+ install your looking at around $1000-$1500.
Re: electric locker???? #601076 05/10/05 03:33 AM
Sounds like the better option. THANKS!
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6204 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-10-22 19:05:28 UTC
