Re: electric locker???? [Re: Jim_Paget] #601077 05/11/05 01:28 PM
MattGold Offline
Hi,
Jim is right. I put in an Isuzu 12-Bolt rather than the D44, but that was mainly for two reasons, first it happened to be that Joe D. had one available and secondly, I could switch from the 4:30's in my truck to 4:56's.
The ARB was the best single addition I put on my truck. The next best was the 33's MT/R's
Matt
92' Rodeo with a lot of DOR parts
Re: electric locker???? [Re: MattGold] #601078 05/12/05 01:12 PM
hunterdan Offline
I've done the GM 10 bolt to the D44 swap as well. Was relatively cheap, less than $300 for all new parts including a rear out of a 97 rodeo. I wanted to go to disc brakes all around, but I couldnt find an axle locally that was out or at a reasonable price, so I got a 2wd rear out of a 4 cyl rodeo that was the same 4.56 gearing I had. I would try to avoid locking the gm 10 bolt, and instead do a swap and lock a 44 instead, you get more options for lockers, LSDs, and gear ratios, as well as a stouter axle and cheaper lockers. The whole swap took me and my friend less than 8 hours to do, (lots of screwing around). Im sure if you did a search on here, you could find my thread about the ordeal, should have lots of info in there about axle choices. And almost of the stock isuzu axles, as long as they were leaf sprung, should bolt in. Even the rear abs sensor on the new axle plugged into the old socket.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: electric locker???? [Re: hunterdan] #601079 05/13/05 03:17 AM
That is something to think about!
But I'm really trying to keep the costs as low as I can. I just found an electric locker that's pretty reasonably priced..... Auburn Gear ected electric locker... If that could work, I would sure love to avoid an axle swap. For some reason, it's pretty hard to find used parts for my Isuzu around here.
So does anyone know about those Auburn Gear electric lockers?
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5974 MB (Peak: 0.6527 MB) Data Comp: Off Server Time: 2026-07-14 08:17:52 UTC
