Auto Transmission Lockup Problem #607096 05/26/05 12:54 AM
W
Wildcat_4R Offline OP
I have an 87 4-runner w/ a motor that I just rebuilt. After I got all the engine bugs figured out....rough idle, O2 sensor wire, etc...I took it out for a spin. It seems as though the torque converter is not locking up when it should. The motor is reving to about 2000rpm before the trans. kicks in and the truck starts to move. It seems to be ok once the truck starts moving. A few times when I was at a stop (still in drive) I could feel the truck try to lurch foward like it locking up then. Anyone have any ideas on where to start with this problem? <img src="/forums/images/graemlins/confused.gif" alt="" />
1987 4-Runner with a "slightly modified" 22RE
Re: Auto Transmission Lockup Problem [Re: Wildcat_4R] #607097 05/26/05 02:36 AM
ZUK Offline
Is the fluid red and is it to the full mark?
mostly stock
Re: Auto Transmission Lockup Problem [Re: ZUK] #607098 05/26/05 03:45 AM
W
(shakes head in shame)
Wasn't filled up all the way...should have double checked.
Re: Auto Transmission Lockup Problem [Re: Wildcat_4R] #607099 05/26/05 05:30 AM
willzrunna96 Offline
\ <img src="/forums/images/graemlins/cheers.gif" alt="" /> try pulling codes for the hell of it if you see the O/D blinking continuosly then nothing is wrong. i think a code 64 if a defective lock-up solenoid
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-06-17 15:47:36 UTC
