Page 8 of 17 1 2 6 7 8 9 10 16 17
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: DC] #607206 07/20/05 05:35 AM
Angelo Offline
Damm guys... keep your panties on..
Oops, sorry DC, let me pull them back up <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" /> I'm kiddin, just building up the hype <img src="/forums/images/graemlins/kewl.gif" alt="" /> Whenever you have time is cool. Hope everything is going well. You're doing alot of mods at one time. It should drive alot different then what you were used to before. Hell, when I did a 2" body lift it felt different driving it.
The gas tank shouldnt be that hard to do, just make sure you dont have a full gas tank when you decide to change it <img src="/forums/images/graemlins/drunk.gif" alt="" /> You should be able to see everything that needs to come off and put back on the new one.
Good luck,
Angelo
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: Angelo] #607207 07/20/05 06:51 PM
lordtrunks Offline
I've done its pretty easy man just use a floor jack to drop it down.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: lordtrunks] #607208 07/21/05 02:16 AM
DC Offline OP
Ok.. yo can start to take your panties off now. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
[Linked Image] [Linked Image]
There are some differances with the ones on the web. Like this one uses 2 joints to transfer the torsion bar to the lower a arms. I believe the other one was older model. Also if you look at the 2nd pic with the middle a-arm, there was a bracket that came out. They couldnot figure out for the life of them what that was for. Also it got in the way of the steering asembley. So they cut it off. Now all they are waiting for now is the front 4wd assembly from the gear shop. And the rear thrid member.
As for the gas tank.. I anded up droping it off a the shop since they have it up on jacks already.
DC
97Sport A/T 33's
locked front & rear 4.90
5" IFS Lift
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: DC] #607209 07/21/05 02:33 AM
DC Offline OP
So I'm told there was alot of banging and hammering to get things to fit. Alot of the holes didn't match up. Ummm not because of the lift but a little bit on my side. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Once again trail scares. <img src="/forums/images/graemlins/shiner.gif" alt="" />. So they had to drill out some of the holes for the bolts to fit. It now looks like fri-for the finish date.
DC
97Sport A/T 33's
5" IFS Lift
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: DC] #607210 07/21/05 04:00 AM
StockRaider Offline
wow, thats nice looking.. now would that fit my 89 V6?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: StockRaider] #607211 07/21/05 04:43 AM
justice Offline
Well It sure looks beefy...The spindle drops look top notch and I like the grease fittings on the doohickies that push down on lower A arm.
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: justice] #607212 07/22/05 03:53 AM
Lloyd Swartz Offline
There is certainly going to be alot of serious equipment at this years Sierra Challenge <img src="/forums/images/graemlins/kewl.gif" alt="" /> Looking good Dat! All I keep hearing about is weekend work sessions, late nights, and screaming mechanics, must be getting close to Sierra Challenge time <img src="/forums/images/graemlins/lol.gif" alt="" />
" looks like somebody went underneath with a sledge hammer and hit every piece of metal there was" <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: Lloyd Swartz] #607213 07/22/05 05:54 AM
DC Offline OP
Looks like the front bearing seals are coming back to bite me in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />. Nobody has them here so they have been ordered from two separate locations from the eastern coast. Whats with the eastern coast? I had to order my 4.90's from there too. Is there a secret stash of Mitsu parts out there. We westerners are being left out. Anyways back to the seals. Everything is put together for the front diff. the 4.90 and ARB fit perfectly.(thanks Vic) They are just waiting for the seals. Then it goes up and the rear goes to the shop for the 4.90's. (they only have enough stands right now to hold the front up. I think they have 4 trucks/projects going togheter at the same time)
Sooooo the date of finish is being pushed to next week.
DC
97Sport A/T 33's
5" IFS Lift
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: DC] #607214 07/22/05 06:01 AM
52degrees Offline
There are no aftermarket seals available locally? That's kind of a suprise to me. But on the other hand, the parts department at my shop couldn't find any shocks for mine unless they are Monroes <img src="/forums/images/graemlins/barf.gif" alt="" />
Clay
KG6VNX
Re: 5" lift kit for GEN I and GEN II/strada/sport [Re: 52degrees] #607215 07/24/05 04:37 AM
DC Offline OP
I'm not sure about after market seals but I think they are oem.
as for the shocks. You don't buy listed shocks for the truck thats modded. You measure the full length extension and compresion, now this will give you the shock length.
Now you just need to pick which compression rate and rebound. This is dependent on your vech weight and spring rate. Ie for the mitsu'd if they are cranked the compresion should about med. Etc.. shocks are not rocket science. Unless your setting up for the baja or jumping it's easy.
sorry about the shock stuff. I'm getting something for this lift. (cheap)But with this system of choosing. Well the baja racing guys at the shop are getting them.
DC
97Sport A/T 33's
5" IFS Lift
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6578 MB (Peak: 0.7690 MB) Data Comp: Off Server Time: 2026-06-09 21:34:01 UTC
