SAS folks #608203 05/28/05 10:25 PM
surlynkid Offline OP
what are you doing with your master cylinder? stock 1"? with rear disks, there is no way what i have will work. i want a chevy, but they are too long. the windshield wash bottle is in the way on 95-96 trucks. i guess i need to find a smaller bottle and retrofit it in, so i can put the chevy master in. i put the 1" T100 master on teh 4runner since i also put the bigger T100 calipers on the 4runner.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: SAS folks [Re: surlynkid] #608204 05/29/05 03:19 PM
adam Offline
Stock. The 5speed has made it agreeable to leave it that way.
I've been trying to think how you could relocate it. Got room in front of your battery? Otherwise I think your plumbing will be a mile long.
~Adam
Re: SAS folks [Re: adam] #608205 05/30/05 04:29 AM
Jake97T Offline
in 1997 Toyota put the wash bottle in a worse spot, right in front of the passender side wheel well, perfect spot to rip it off with a fully flexed SAS T100
Re: SAS folks [Re: adam] #608206 05/30/05 04:39 AM
can you lock up the tires without any problems?
the 1997 wash bottle location sucks for SAS with my custom winch bumper. i am thinking about a small 88 4runner bottle in teh same spot as teh 1995-1996.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: SAS folks [Re: surlynkid] #608207 05/30/05 03:49 PM
adam Offline
I've had two occasions I can remember where I needed to, and it did. The pedal was pretty close to the floor, though. So it did it without any problem, but I can't say I liked it.
~Adam
Re: SAS folks [Re: adam] #608208 05/30/05 04:04 PM
Jake97T Offline
Then there is always the 50's style rubber bag idea... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: SAS folks [Re: Jake97T] #608209 05/31/05 02:35 PM
bkg Offline
There is a serious lack of pictures in this thread. <img src="/forums/images/graemlins/smile.gif" alt="" />
Brian K. Gallus
Re: SAS folks [Re: bkg] #608210 05/31/05 04:57 PM
ErikB Offline
Toyota Moderator
You could try to find a Toy style 1-1/16" bore and see how you like it. You'll probably be happiest with a 1-1/8" though, aside from having to figure out the washer res. problem.
http://home.4x4wire.com/erik
Re: SAS folks [Re: ErikB] #608211 05/31/05 11:08 PM
those were only in teh 1 ton, correct?
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: SAS folks [Re: surlynkid] #608212 06/01/05 08:57 PM
ErikB Offline
Toyota Moderator
Not necessarily. Supposedly it was on all the ABS models, but I've seen it ones w/ and w/o ABS. I dunno what the real qualifications of having the bigger bore were.
Technically, I'd think the 1-ton would have the smaller bore to give better braking power. I saw a 1-1/16" in the JY on a 2wd T, so maybe that's a good place to start looking? It would make sense to reduce the braking power/leverage on a (somewhat lighter?) truck with smaller tires.
I know Brandon Miller found a 1-1/16" in some Toy car in the junkyard and used that. Sorry I can't be more helpful/specific though.
PHP: 7.4.33 Page Time: 0.005s Queries: 16 (0.004s) Memory: 0.6400 MB (Peak: 0.7597 MB) Data Comp: Off Server Time: 2026-05-30 05:29:53 UTC
