If your timing is off will it throw a cheak engine light? #609902 06/02/05 01:28 PM
thecat Offline OP
Just courious.
Toyota master
Re: If your timing is off will it throw a cheak engine light? [Re: thecat] #609903 06/03/05 12:26 AM
Dandeman Offline
Toyota Moderator
What year vehicle and which engine?
Re: If your timing is off will it throw a cheak engine light? [Re: Dandeman] #609904 06/03/05 01:39 AM
thecat Offline OP
Oops. 96 t100 3.4 2wd
Toyota master
Re: If your timing is off will it throw a cheak engine light? [Re: thecat] #609905 06/03/05 03:06 AM
yeap
the engine being out of time will cause a hole bunch of problems that he computer will throw codes for
Re: If your timing is off will it throw a cheak engine light? [Re: thecat] #609906 06/03/05 03:22 AM
kewlynx Offline
**ubi apis- ibi salus**
Re: If your timing is off will it throw a cheak engine light? [Re: thecat] #609907 06/03/05 04:02 AM
Dandeman Offline
Toyota Moderator
All cars and light trucks built and sold in the United States after January 1, 1996 are required by federal law to be OBDII equipped, which includes your 3.4L engine.
And on an OBDII equipped engine, the engine computer (or ECU) has total control of the ignition timing.. and there is no way for you to set or adjust it..
Go to an Autozone or one of those places that lets you use an OBDII scanner for free and read out the error codes that have turned on the check engine light.. and post that info here..
That will give some idea what the problem is..
Re: If your timing is off will it throw a cheak engine light? [Re: Dandeman] #609908 06/03/05 03:31 PM
thecat Offline OP
There is no light yet but something is deffinantly off. I have no power over 3K rpms.
Toyota master
Re: If your timing is off will it throw a cheak engine light? [Re: thecat] #609909 06/04/05 05:04 AM
kewlynx Offline
Pull the tube off the t'body and see how much carbon buildup you have; might be time for a good little tuneup. Just a thought.
Re: If your timing is off will it throw a cheak engine light? [Re: kewlynx] #609910 06/04/05 07:18 AM
thecat Offline OP
Tune up? I have replaced the spark plugs, spark plug wires, throttle position sensor, all the vacume lines, cleaned the entire intake down to the block, cleaned the maf. I am out of ideas. A V8 swap is starting to sound really good at this point.
Toyota master
Re: If your timing is off will it throw a cheak engine light? [Re: thecat] #609911 06/06/05 03:39 AM
You have cleaned the air intake, installed new plugs spark and the gas? Gas filter or something might be restricting the fuel to the engine is my guess. Good luck.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6332 MB (Peak: 0.7394 MB) Data Comp: Off Server Time: 2026-07-17 06:14:14 UTC
