Page 1 of 4 1 2 3 4
Recovery Gear - Trail Fixes - What to carry #610019 06/02/05 09:55 PM
A
AZPetrak Offline OP
I am starting a list of things I should carry for light trail fixes and would like to see what you guys carry with you on the trail.
Here is the unabridged list, use it as a reference:
TOOLS
pliers
needle nose pliers
channel locks
vise-grips (needle nose)
crescent wrench(s)
full socket set (extensions, universal)
torx set
screwdriver set
full wrench set
wire cutters
hammer
c-clamps
work light (12v)
utility knife
knife (3-4 in)
hack saw
strap wrench
RECOVERY
tow strap
high lift jack
D-rings
come-a-long
extra high strength cable
tire repare/patch kit
compressor
jumper cables
snach block
tree saver
WEATHER
ponchos
tarp
sunscreen
insect repeller
blanket
MISC
bailling wire/cable
plumber strap
duct tape
electrical tape
auto trans fluid
steering fluid
oil
brake fluid
first aid kit
hose clamps
nuts & bolts (diff sizes and lengths)
2 gal water
gasket sealer/maker
matches
funnel
fire extinguisher
oil absorbant
chain
wire ties
welding rods
JB weld (or other epoxy)
SPARE PARTS
fuses
u-joints - front axle
u-joints - drive shaft
tie rod ends
serpentine belt
starter (autos)
Dana 35 axle shafts???
What am I missing, or what have you used/needed???
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610020 06/02/05 11:04 PM
RockJock Offline
Toilet Paper, water and MRE's
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610021 06/02/05 11:25 PM
Spare tie rods/ ends.
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610022 06/03/05 12:03 AM
tomriddle Offline
torch. i hate when stuff won't come apart.
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610023 06/03/05 12:14 AM
BigJim Offline
This list is funny! I might be talked into carrying all that stuff in my ride if it had a 900 gallon gas tank!
Jesus are you planning on pushing it off of a clift? If it is that junkie maybe you should get a more dependable one.
I would carry some cokes and munchies and wear a LONG teeshirt just in case.
Re: Recovery Gear - Trail Fixes - What to carry #610024 06/03/05 12:32 AM
A
AZPetrak Offline OP
good call, something that probably breaks often.
Something else I thought of was a serpentine belt - i will add to the list
2007 4x4 Tacoma Dbl Cab with TDR and rear locker - stock for now
2001 Wrangler Sport - sold
1998 Rodeo S 4x4 - traded in
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610025 06/03/05 12:43 AM
I agree with BJ, that is ALOT of stuff. For a Trip out for the weekend or just a day, that is a bit too much for me.
Re: Recovery Gear - Trail Fixes - What to carry [Re: BigJim] #610026 06/03/05 12:48 AM
A
AZPetrak Offline OP
This list is funny! ... If it is that junkie maybe you should get a more dependable one.
I wouldn't call a 2001 TJ with 34k miles a junkie.
OK, lets say you are out wheeling and your oil pressure sensor breaks and is spraying oil while the engine is running, how is your t-shirt and munchies going to get you off the trail? What if you bust a u-joint or tie-rod???
The basic principle is to carry enough stuff so that you can limp off the trail for the things that commonly go wrong, i.e. - u joints, tie rods, belts, hoses etc. Out in the West/South West there are miles and miles of open land to wheel on, where it can take hours to get back to a town and no cell service. You need to carry enough stuff to try to get you off the trail. East coast wheeling is a little differnt in that the areas tend to be smaller and usually there is a town near by (I use to live in Ohio).
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610027 06/03/05 02:37 AM
valleycat Offline
i would add a spill cleanup kit to your list. at least some oil absorbant and a garbage sack to pack out your contaminated dirt.
the list looks good to me. it doesn't seem excessive. i would throw in some spare lugnuts and since your taking a tire plug kit, you probably should take some type of air compressor to fill your tire back up.
i don't usually pack that much stuff on trail. i usually 4 wheel in areas where camp is nearby. i don't even take a spare tire. if i need something, i just get a ride to my trailer and get it. if it's a big run like jamboree or something, i'll take a bunch of stuff so i can fix quick and not hold up a group.
Re: Recovery Gear - Trail Fixes - What to carry [Re: AZPetrak] #610028 06/03/05 03:00 AM
Berkeley Offline
Jeep Moderator
Looks pretty good, though I don't carry that many tools. When I had a Dana 35, I had axle shafts. The only thing worse than wheeling with a Dana 35 is not having spares when you break it. Friends don't mind helping, especially if you've got spares.
I'd add a chain and a tree-saver strap to the recovery list. A snatch block (pulley), too. I use all that stuff lots.
The most important "emergency gear" you can have with you is three or four other rigs (friends) on the trail with you. Even if you burn to the ground, you're friends won't leave you there. We've all heard horror stories. The common thread is that, no matter how many days it took, every one gets home.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 1.577s Queries: 16 (0.010s) Memory: 0.6371 MB (Peak: 0.7575 MB) Data Comp: Off Server Time: 2026-07-15 00:04:50 UTC
