Page 1 of 3 1 2 3
How to Remove side graphics on a 90' extra cab? #610237 06/03/05 03:32 PM
I have the factory graphics on the side of my 90' toyota pick up and I want to take them off. Please let me know the best way to do this. Thanks! <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: How to Remove side graphics on a 90' extra cab? #610238 06/03/05 04:29 PM
mt_goat Offline
I've done it on other trucks (but never after 15 years) by using a hairdrier or the hot sun to soften the adhesive and just start pulling it off. Then use some adhesive remover to get the rest the the glue off. Warning: you know the paint anound the graphics has probably faded a lot in 15 years of sun exposure so there will be a big color difference between the two areas. I did it on a silver truck that was just 2-3 years old and I could tell where the graphics were.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: How to Remove side graphics on a 90' extra cab? [Re: mt_goat] #610239 06/03/05 05:51 PM
calisurferdude Offline
Goof-off, WD-40 and a razor scraper.
1987 Toyota 4x4 w/94 bed, 5spd. Rancho RS5000 shocks Firestone 31's, AISIN hubs, Kenwood deck
1991 Toyota 4Runner 3.0/V6, 5spd. on 31's
Re: How to Remove side graphics on a 90' extra cab? [Re: calisurferdude] #610240 06/03/05 06:29 PM
I figured you would probably be able to tell where they were after I take them off and I am going to try to blend the paint as best as I can after I do so, but I plan on eventually repainting it anyway so it won't be a big deal....
Razor scraper???? do you mean a razor blade???? That would destroy that paint I have right now....
Re: How to Remove side graphics on a 90' extra cab? #610241 06/03/05 07:47 PM
4Crawler Offline
Here is how I removed some stripes from my '85. There is also supposed to be an adhesive removal wheel from 3M that works well. Kind of like a big pencil eraser, never tried one of those.
Re: How to Remove side graphics on a 90' extra cab? #610242 06/03/05 07:48 PM
SALMONHEAD Offline
If you have to do any scraping to get things started, I used a new plastic bondo spreader.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: How to Remove side graphics on a 90' extra cab? #610243 06/03/05 07:54 PM
hair dryer might work but one of those heat guns from auto shop might be a little hotter. Also a buffer with some aggressive polish or compound would be good too to help blend and remove contaminants.
razor blade - hahahaa awesome <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: How to Remove side graphics on a 90' extra cab? #610244 06/03/05 08:18 PM
Thanks for the suggestions.....4crawler....what did you use as a "soft scraper" when heating the decals up and peeling them off??? I will try this approach.
Re: How to Remove side graphics on a 90' extra cab? #610245 06/03/05 08:31 PM
4Crawler Offline
As you can see in the picture on that web page, I used a scrap of wood for a scraper along with the heat gun. Worked well and did not scratch the paint.
Re: How to Remove side graphics on a 90' extra cab? [Re: 4Crawler] #610246 06/03/05 08:58 PM
I thought that is what it was but I wasn't sure. Thanks!
Anybody heard of using an eraser wheel on the end of a drill????
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6271 MB (Peak: 0.7484 MB) Data Comp: Off Server Time: 2026-06-14 02:18:51 UTC
