Page 7 of 14 1 2 … 5 6 7 8 9 … 13 14
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611556 07/07/05 12:02 AM
BoostedInline6 Offline
Impressive! I'm going on 6 weeks just doing my rebuild. I was waiting for a headgasket from Cometic for quite a while, I bought the last OEM crank bolts in the country and Spec (the clutch manufacturer) sent me a damaged clutch disc, then sent me a throw out bearing rather than a replacement disc. [Linked Image]
If it weren't for relying on others, I would be done!
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: BoostedInline6] #611557 07/07/05 12:41 AM
4
4RnrRick Offline OP
[color:"red"] heres the short VIDEO! [/color]
http://www.rcpics.net/view_single.php?medid=60448
Download it while you can because this site I uploaded it to does randomly delete stuff.....
Project Quasimodo
'85 Xtra Cab (2wd, 22RTE, Auto => 4wd, 3RZ, w56, 2.28x4.70)
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611558 07/07/05 03:16 AM
Sounds mean! Nice writeup by the way, It's been kind of addicting to tune in every day and see what you've done!
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap #611559 07/07/05 03:34 AM
4
4RnrRick Offline OP
Well the only thing that I've got done tonight is I made the connector tube for the exhaust manifold because I've got to watch my daughter tonight while the wife is out. The factory exhaust does the two tube into one about 2 feet after the manifold so I had to shorten that up for my crossover tube. I'm also going to run 2 1/4" exhaust on this motor. hopefully I can have it down to the exhaust shop by this weekend......I've gotten a quote of $200-$225 for the tube work and the muffler, I'm supplying the CAT.
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611560 07/08/05 08:35 AM
4
4RnrRick Offline OP
Well tonight I tried finishing up some of the minor stuff to make sure I could actually drive it down to the exhuast shop Friday morning....you know, coolant, oil, power steering, clutch, etc... Well I'm all set to get it down there but I still got a lot of the little stuff to go. Mostly because I'm going to rewire all my accessories with this dual battery install.
I did chain the motor mounts down. and I put a little twist to it. I put a couple chains at an angle trying to prevent the motor from moving backward. This should help stop the EGR from hitting the firewall or the plenum from hitting my brake booster.
I then did some HOT LAPS around the neighborhood with no hood or doors.... I did get it up to 55mph already which IS legal on that road... Man is this thing loud with no exhaust! Hard to get a performance compraision now, but after the exhaust is installed I can run the tests again. so far I'm really happy with it.
Now as for quirks, It has some that I need to work on. The EFI relay appears to have power and ground to it all the time. so I'm affraid to leave the battery connected otherwise it could drain the battery. Plus the relay is getting warm to the touch. Just something I'm going to have to figure out.
The engine doesn't want to idle very well at start up. you have to give it some gas for say the first 5 seconds before it takes the idle. again I haven't tuned anything yet since I'm waiting for the exhuast.
I did find a loose banjo fuel fitting which was leaking gas. That could of been bad - Really bad! I just forgot to tighten it when I was putting the engine back together. but luckily that was an easy fix and nothing bad happened!
Here is what it looks like now! Hood, Grill, Doors are all back on! and just to let you guys know, I didn't have to modify the hood any for that radiator.
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611561 07/08/05 08:45 AM
kewlynx Offline
Wow-- ya need to get it outside in the daylight for us Rick. Whoo-hoo-- the home stretch!! Kinda diggin that flame job there.
**ubi apis- ibi salus**
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: kewlynx] #611562 07/09/05 05:49 AM
4
4RnrRick Offline OP
Heres how the exhaust turned out. Ended up being $300 for everything from the collector back and I provided the Cat and the collector. Its all in 2 1/4" exhaust and a 'turbo' muffer was use to keep everythign nice and quiet - I'm just sick and tired of my previous loud exhaust systems.
I choose to run the exhaust under the bellhousing instead of under the oil pan because I still wanted access to the bell housing bolts and the oil pan bolts.
The installed did a really nice job at bracing every point on the exhaust system. I was pretty clear on how I wanted it done and he exeeded my expectation. Also even doing it this was there is no way the driveline can hit the exhust with dual cases even with my low lift.
And here is the crossover. nice and clean.
And he was able to tuck the cat up nice and high above teh 2" lifted Sky's crossmember.
And then down next to the the traction bar (it not quite as close as it looks) and dumping it out right behind the center of the axle. that last Jog in the exhaust is mostly for sound deadening and for getting the exhaust away from the springs.
As far as driving impression so far..... I REALLY like it! Feels torque off the line and this motor likes to REV! The power band just keeps going and going.... Its really nuts! And I still haven't gotten around to even checking the timing yet! The distrubitor is still in the same location I put it when I bolted everything back together.
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: BoostedInline6] #611563 07/09/05 09:40 AM
I gotta say this the single most impressive write up I think I have ever seen on any forum of any kind.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Nice rig.
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap #611564 07/09/05 09:58 PM
4
4RnrRick Offline OP
Thanks....
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611565 07/10/05 04:33 PM
4
4RnrRick Offline OP
Well I finally found my wiring gremlin! I was getting a 1.3A drain on battery only after I connected the battery and started the engine once.... plus the heater fan would then have power to it after I pulled the key out..... And the other thing that keyed me into a problem was my EFI relay was getting warm to the touch...
Basically when I wired the EFI main relay I just spliced into the main harness where I needed to cut the existing wire and then splice into it. I was getting a weird power feed back though the system that after turned the key for the first time and it would engage the heater relay and then it would send power to the wrong side of the efi relay. It was a PITA to find but I finally did!!!
The other thing I worked on was adjusting the 4cyl tack to read the correct RPM for the 6 cylinder motor. Well that fix was real easyusing this info:
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
But I had one heck of a time trying to figure out what the actual RPM of the motor was! I couldn't figure out how to hook up my dwell/tach meter to the coil to get it to read RPM.... Everytime I hooked it up I was only reading 150-200 RPM. I even borrowed two other meters and they did the same thing. So I finally gave up on that and I was able to wire in the donor car tach from the cressida instrument cluster. but the odd thing about that is that was only showning 500 rpm at idle..... to me it sounded more like 700 ish.... so anyway I then hooked up my 4runner tack and set it accordingly. I would still like to figure out what I was doing wrong so I can compared the actual rpms to the tach as say 3000 rpm.
So I basically spent all yesterday working on those problems.... doesn't feel like I did anything productive!
And here is going to be my last entry on my actual costs. I don't expect to be buying anything else for this motor swap. I've also still have about $200-$300 of more stuff off the motor that can be sold. so that would put my total cost for this motor swap and dual batteries around $1700-$1800.
Code
[font=courier]
*...4RnrRick's list of actual motor swap costs...*
*.........Prices Include Shipping Costs..........*
*.Descrpition..............................Price.*
*7M-GE engine 89 Cressida 153K w/ 90 day warranty*
*from local wrecking yard. Motor harness w/ ECU,.*
*coil/igniter, injector resistor, AFM, Exhaust ..*
*manifold, 02 Sensors, Oil pan, pickup, dip stick*
*Supra 7M 5MGE upper motor mount brackets, 5M/7M.*
*bellhousing, flywheel, clutch fork, slave cyl...*
*starter, and every else typically supplied with.*
*a motor swap............................$950.00.*
*Motor credit for Bad Head Gasket.......($115.00)*
*Radiator, new 1988 V6 3-core, 2" thick..$115.00.*
*14" Electric Fan, Hayden #3710..........$139.99.*
*185F Thermostat Relay, Hayden #3652......$22.99.*
*Radiator hose, NAPA 8761.................$17.92.*
*Radiator hose, NAPA 8698.................$11.73.*
*Radiator hose, NAPA 7775.................$12.16.*
*Radiator hose clamps......................$6.33.*
*Material for splicing Radiator hose.......$4.99.*
*OEM Replacement Clutch Kit..............$150.00.*
*Resurface flywheel and exhaust manifold..$70.00.*
*Clutch Slave, 'Napa' #37606..............$30.90.*
*Head Gasket, FelPro #9473PT.............$102.73.*
*Valve Cover Gasket Set, #ESP VS50303R....$21.14.*
*Front Crank &amp; Timing Gskt Set, #TCS45732.$24.28.*
*Rear Main Seal, Knecht's #ESP 228010.....$16.35.*
*Exhaust Gasket, Knecht's #ESP MS92327....$12.46.*
*Intake Gasket Set, Knecht's #ESP S93544..$11.72.*
*Cam Shaft Seal Set , #ESP45424...........$11.03.*
*Oil Pan Gasket, Knecht's #OS 3435........$10.58.*
*Bulk Gasket material......................$2.99.*
*Exhaust Downpipe Donuts, Napa F-14592.....$6.28.*
*2 1/4" Exhaust connector for collector....$3.07.*
*Professional Exhaust with muffler.......$300.00.*
*Spark Plug Wires, Knecht's #ESP 09216....$63.88.*
*Distibutor Cap, Knecht's #KEM W3082......$10.79.*
*Spark Plugs, Knecht's #NGK 2241 Qty(6)....$9.54.*
*Rotor, Knecht's #ESP JR120T...............$5.08.*
*Timing Belt, Knecht's #CLO B126..........$18.48.*
*Alternator Belt, Knecht's #GDY 510K5.....$12.59.*
*Power Steering Belt, Knecht's #GDY 350K4..$7.20.*
*1989 Supra 7M-GE oil pump, new (ebay)....$85.25.*
*1989 Supra oil pump hardline.............$39.61.*
*1989 Supra oil pump ball sleeve &amp; gasket..$6.11.*
*Fram Sure Oil Drain Plug, 18mm x 1.5.....$15.69.*
*Antifreeze................................$9.99.*
*10W-30 oil...............................$10.20.*
*Dot 3 brake/clucth fluid..................$3.40.*
*Power Steering Fluid......................$2.99.*
*Used 210 York from Volvo (V-Belt)........$30.00.*
*New 6 gr pulley&amp;clutch, Kenworth KA1480..$69.95.*
*Red Top Optima Battery...................$93.00.*
*Battery tray &amp; hold downs................$11.98.*
*Battery marine terminals..................$1.98.*
*Battery isolator, 95 amp.................$39.99.*
*6 Amp Circuit Breaker.....................$4.77.*
*(6) Fuse holder, 'Accele' #5415..........$14.95.*
*Battery Wire Lugs.........................$1.98.*
*Wire loom, black split - 3 sizes.........$15.96.*
*Micro Potentiometer 4.7K, RS #271-0281....$1.19.*
*Label Maker..............................$24.96.*
*Vacuum Hose...............................$1.50.*
*Fuel line and hose clamps.................$9.94.*
*Power Steering Hose......................$17.52.*
*Engine Paint, Semi Gloss Black............$4.60.*
*AntiSeize.................................$4.59.*
*Ultra Black RTV, Permitex.................$3.99.*
*Blue Shop Towels, (3 rolls)...............$6.00.*
*Metric Hardware..........................$23.56.*
*Misc Steel from metal recycler...........$17.15.*
*Chain for motor mounts, 5/16".............$3.50.*
*Engine Repair Manual CD 7MGE/7MGTE, ebay.$18.12.*
*Chiltons Repair Manual for 1989 Cressida.$17.95.*
*Borrowed 1989 Supra Electrical FSM on CD..FREE..*
*Borrowed 1991 Supra Electrical FSM........FREE..*
*Borrowed 1991 Cressida Electrical FSM.....FREE..*
*Borrowed Engine Stand and Hoist...........FREE..*
*Sold, Thorley Header with O2 Sensor....($125.00)*
*Sold, Short Block W/ Timing set &amp; pan..($150.00)*
*Sold, Head, DOA 270 Cam, LCE Adjust timing gear.*
*&amp; LCE Red Powder coat valve cover......($150.00)*
*Pending, EFI Conversion Parts..........($225.00)*
*Total Dollars Spent as of 7-8-2005......$2032.56*
[/font]
Project Quasimodo
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 3.577s Queries: 16 (0.011s) Memory: 0.6666 MB (Peak: 0.7857 MB) Data Comp: Off Server Time: 2026-11-15 14:21:36 UTC
