Page 9 of 14 1 2 7 8 9 10 11 13 14
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611576 07/21/05 02:55 AM
Great job Rick!! And to everyone else, I just ran into this guy as we were both driving down the highway. We came to a stoplight and I commented on his f&#kin bada$$ 4runner. (mine's pitiful in comparision). But this thing looks SWEET! I've never seen a 4runner take off that fast before either.
Awesome job Rick, I hope to see you around these parts again smile At least now I know there's someone in town with some serious engine knowledge <img src="/forums/images/graemlins/cheers.gif" alt="" /> Maybe you could post pics of your whole ride so everyone can see <img src="/forums/images/graemlins/kewl.gif" alt="" />
Take it easy smile
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap #611577 07/21/05 04:59 PM
4
4RnrRick Offline OP
Ah, heck, your being too nice. It sure is funny how you met some people......
Anyways, heres some pictures of the rig, so if you see me, say hi!
Project Quasimodo
'85 Xtra Cab (2wd, 22RTE, Auto => 4wd, 3RZ, w56, 2.28x4.70)
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611578 07/21/05 07:00 PM
4
4RnrRick Offline OP
Second tank of Gas......
155 miles and 11.92 galons
13.0 MPG, Not as good as I would like to see but I still need to look into my timing problem. I don't think the ECU is advancing the spark with changes in RPM.
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611579 08/09/05 04:16 PM
4
4RnrRick Offline OP
Well heres a final install picture of the 7M-GE in my 85 4Runner...
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611580 08/10/05 08:24 PM
4
4RnrRick Offline OP
3rd tank of gas now .....
174 miles and 12.99 gallons = 13.4 MPG
Well I definately see a trend here in my MPG.... I hope I can figure it out because I really should be getting more!
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611581 08/10/05 08:55 PM
Another kudo from me, Rick. You answered a LOT of questions I had about putting one of my spare 7Ms into the 1st gen project racer. It won't be a turbo, though, because it boots me waay up in competition class!
'92 Supra Turbo/Targa/5-speed basically stock (225RWHP/13.98@97MPH on stock boost)
'89 Supra Turbo/Targa/5-speed TD06/A'PEXi/Aeromotive (295RWHP/12.34@111MPH @ 14psi)
see them at http://www.geocities.com/suprarossa
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611582 08/29/05 06:36 PM
4
4RnrRick Offline OP
Well, this weekend was its real test. I drove up to TSF (~3 hours away) to run trails all day and then back home. It ran great all day long. Curently the cooling system isn't quite right. Running down the freeway in the cooler morning temperature the engine temp gauge was constantly cycling up and a down. But in the afternoon in the warmer temps it just stayed in the same spot (just below horizontal postion on the gauge). If I was running higher rpms and low speed the temp would climb until the electric fan kicked on. And then it would drop back down to normal and stay there as long as the fan was on. so I just left the fan override switch in the on position when I was on the trails so I didn't have to watch the gauge constantly going up and down. if I was on the gravel roads, I could turn the fan off and it would be fine. so it looks like I need to get a different thermostat and/or a different thermo switch for the fan because its not quite right, but I DO have enough cooling power with this V6 Truck radiator. I just don't like the temps cycling up and down.
As for motor performance, it seems like you can't lug this engine down like a 22R Series. if your keep it about 1200 rpms or more your fine, but any lower than that it seemed to stall out pretty easy. I stalled it out ALOT on takeoffs because I'm just not use to slipping the clutch that much compared to the old motor. Good thing I didn't use a ceramic clucth!!!
For gravel road running, this motor is awesome! I was able to keep the rpms right around 3000-4000 on the roads and on any corner you could lay into the throttle and start power sliding. The throttle around this rpm is also really smooth which is great for drifting because you could stay in control and really control the slide with just how much thorttle you give it. It was night and day different then the 22RE I had. With that you had to work on getting the slide to start with a small jerk of the wheel. and you only had so much power available. And the power band up in the high rpms is REALLY long. You have consistant power all the way up to 6000 rpm. and then when you shift you still have more power. with the 22R series, if you shift out of your gear, your pretty much bogging down and screwed! You can run the roads at lower RPM just fine, its just not as fun for drifting.
I tried some steep hill climbs and really liked how it felt. With this motor if your around 2000 rpm running a steep climb and want to accelerate, you can! just lay into teh throttle a little more and away you go. With the old motor I could do this but no where nearly as fast .
Heres some pictrues from the day....
TSF OHV, 7-up
TSF OHV, Little Crusher
But then on the way home all hell broke loose
Coburg rest stop on I-5
Well so much for this junkyard 7M, I lost the bottom end! Sounds like a rod bearing to me. Luckily I was only about 40 miles away from my house and I was able to make it to a rest stop! So I called up Wheelie_Pete for a tow to his house which was about 10-15 miles. Only to get pulled over my the Finest Coburg Highway Police. (These guys suppliment their city police budget with speed traps on I-5. The state actually had to put a limit on them because they where pulling in too many $$$) Anyways we where informed that it was illegal to tow with a tow strap! go figure...... in the end he said that he wasn't going to cite us, but he said someone else could, basically he said he was going to look the other way. Which was cool.... but it sucked to get harassed like that when all your trying to do is get your junk off the highway!! So after we got it to Petes, I was able to borrow Sky's Turbo Desiel and Trailer @ 11:00pm at night to get the 4runner back to my house. Its not WHAT you know, but its WHO you know!!! Thanks SKY!
So the bottom end is toast in the 7M and luckily I have about 10 days left on my warranty from the wrecking yard so I dealing with them to see whats the next step!
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611583 08/30/05 08:27 PM
Kutter Offline
Sorry to hear about your bad luck with the motor. I have been following you thread with much excitment. I have a silly noob question. I noticed the list of engines you considered at the begining of your project. I was wondering if a Toyota Solara 3.0L V6 would be a possible swap? I think they put out about 200hp and can take a TRD Supercharger to get around 240hp. I wondered if this could be a solution to the length problem of the Supra I/L6 that causes the airconditioner to be left out?
Good luck with the salvage yard.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: Kutter] #611584 08/30/05 11:46 PM
4
4RnrRick Offline OP
But does it bolt to my W56 Tranny using OEM toyota parts........
Maybe - I have no idea but probably not.
Project Quasimodo
Re: 4RnrRick is getting a 7M-GE / 7MGE Motor swap [Re: 4RnrRick] #611585 08/31/05 12:18 AM
BoostedInline6 Offline
Considering everything you've gone through so-far, replacing the shortblock or rebuilding the engine is simple. Stick with it; they really are great engines.
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6552 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-07-09 22:40:02 UTC
