Calmini uses slip-joint connections for their exhaust, is this okay?? #611687 06/06/05 08:33 PM
moose201 Offline OP
I haven't been able to find a quality exhaust shop in St. Louis so I am considering the Calmini cat-back system for my 2003 Rodeo. Based on the photos on their web page, it looks like it is a three-piece system with the tailpipe and flange-pipe connected to the muffler with slip joints. I'm not really familiar with this type of connection....is this customary and does it work effectively on exhaust systems? It seems like it would be prone to leaks. Calmini cat-back Also, I don't know how accurate their photo is, but I don't see the bracket on the muffler for attaching it to the frame rail. Your comments are appreciated. Many thanks, Mark
Re: Calmini uses slip-joint connections for their exhaust, is this okay?? [Re: moose201] #611688 06/09/05 04:47 AM
JohnW Offline
slipjoints are very common. Torque the clamps to spec and all will be fine. Do not over torque them, this will crush the pipe and cause the leaks you are worried about.
2002 Trooper S 5spd, cone filter, Ranchos, Modified for 2WL
Re: Calmini uses slip-joint connections for their exhaust, is this okay?? [Re: JohnW] #611689 06/10/05 08:55 PM
I prefer slip joints; they allow easy disassembly for future muffler changes, etc.
I always paint my exhaust parts with high-temp BBQ grill paint (from Wal-Mart) <img src="/forums/images/graemlins/wink.gif" alt="" />. This prevents rusting, and is much cheaper than the automotive paint, and just as durable.
It's also a good idea to install jamb nuts on the clamps; this prevents them from loosening.
PHP: 7.4.33 Page Time: 1.219s Queries: 15 (0.003s) Memory: 0.5912 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-06-21 12:46:23 UTC
