Bye-Bye old transmission, Hello new transmission.
#612500
06/08/05 05:47 PM
Just got phone call from my dealership. They drop the pun on the transmission and found some metal parts in it. I was questioned about what I did with Trooper, because dealership installed a new transmission just in October 2004. "Nothing special" was my answer. No towing. No over 80 Mph driving.
Now I start thinking about what I will do when warranty will be over.
I hope they will install a new tranny before holidays. Last time it takes 3.5 weeks. I thing the reason for failure was incorrect ATF level. I did not checked it when new tranny was installed. This time I will check everything.
2001 Trooper LS 3" lift,no more Rancho 9000RX, no more 4L30E transmission, ProComp 8" 130W driving lights, Surco roof rack (modified), 110V power outlet, Viair 380C compressor, CB/FRS/GPRS/HF/VHF/UHF Radio, 285/75/16 BFG AT/KO.
Re: Bye-Bye old transmission, Hello new transmission.
[Re: vovkus]
#612501
06/08/05 08:30 PM
Yikes! <img src="/forums/images/graemlins/scared.gif" alt="" />
Dude, that sucks! <img src="/forums/images/graemlins/zombie.gif" alt="" />
[Re: vovkus]
#612502
06/08/05 11:35 PM
Vlad, that's bad, really bad !
I had a hope that we will wheel together these holidays. I am not sure that they will be able to replace the tranny by holidays <img src="/forums/images/graemlins/confused.gif" alt="" />
Let's see how this replacement will go on.
Oleg Axiom 4WD 2004: OME shocks, 32" BFG Mudders, RockSliderz, OME929+2" spacers, Stinkyfab bent RE rear links, front ARB locker, rear No-Slip locker, DOR front axle lowering kit, custom middle section skid plate, IronMan torsion bars. Deceased Rodeo'02 4WD.
[Re: holger]
#612503
06/09/05 12:23 AM
They promised 2-3 days, but this is a dealer promise  Hope everything will be ok and I'll get trooper back soon.
[Re: vovkus]
#612504
06/09/05 12:34 AM
Exactly which 'holidays' are you referring to? Some Ukrainian thing that I am not aware of?
Good luck on the quick fix though. Steve G
[Re: lttlbddy]
#612505
06/09/05 12:49 AM
Some Ukrainian thing that I am not aware of? <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />4th of July <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: lttlbddy]
#612506
06/09/05 01:05 AM
exactly. This is a very special Ukranian holiday. This day, July 4, 1776, Ukranians got a new country to visit and to work in <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: holger]
#612507
06/09/05 04:30 PM
I salute you <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Enjoy . . . hopefully with a healthy transimission. SG
[Re: lttlbddy]
#612508
06/15/05 07:20 AM
Warranty is a good thing, but it is not forever. So, second transmission in 4 years it is too much. What can be a root of the problem?
1. 33" BFG? 2. Transmission cooler? May be the level of cooler is too high? 3. Incorrect level of ATF. I did not check the level, when new transmission was installed. And the quality of work was so bad. Some bolts was loosen, and some of them even not exists.( This time I will check everything). 4. Powertrain Control Module (PCM) failure? 5. Just my luck?
If it will broke again, I think dealer will refuse the warranty. I do not want to be in that situation.
[Re: vovkus]
#612509
06/15/05 12:17 PM
The biggest thing is the ATF level. You've got to make sure it's correct. Too high or too low, and you risk damage. Just make sure that it's correct, and it should last a long time. Then again, it could just be your luck. <img src="/forums/images/graemlins/nana.gif" alt="" />
Here's to good luck with the new one. <img src="/forums/images/graemlins/cheers.gif" alt="" />
