OEM 16x7 steel wheels and suitable replacements #613124 06/10/05 04:07 AM
rheteric Offline OP
After putting on the wider 265/70/16 rubber on my OEM steelies, the chome hubcaps (aka imposters) are no longer holding the rim adequately. I already lost one hubcap on I95 down by the Philadelphia airport (please PM me if you found it <img src="/forums/images/graemlins/zombie.gif" alt="" />) so I figure I should take the plunge and get some alloys before I cause an accident, if I haven't already <img src="/forums/images/graemlins/shiner.gif" alt="" />. I took some quick measurements of an extra stock wheel I have laying around and these are my observations:
16x7 6 spoke (3 raised):
~5.5 inch backspacing
6 on 5.5 with 4 inch center hole
considerable positive offset (not sure exactly how much)
Anyone care to add to my observations please feel free.
My tires rub the mud flaps slightly on full turn. I'm afraid that my aftermarket choices are limited due to the crazy backspacing of these OEMs. Has anyone ever seen an aftermarket with comperable measurements as the stockers, or should I just prepare myself for more inevitable fitment issues? I'd really appreciate any input from anyone with experience replacing this particular wheel. And, yes, I do want a polished alloy to match the rest of the stainless on my Rodeo <img src="/forums/images/graemlins/baby.gif" alt="" />.
TIA
-Eric
(Note that wheel width statements have been changed from 8" to 7 inches upon realizing that I'm a jackass and can't read a ruler)
Re: OEM 16x8 steel wheels and suitable replacements [Re: rheteric] #613125 06/10/05 04:22 AM
If you want new/refurbished-like-new,
http://www.wheelcollisioncenter.com
is right in our neck of the woods.
As for fitment, most aftermarket don't go as deep on offset, so you end up with wheel/tire assemblies that protrude anywhere from an inch or more out from the axle compared to factory spec.
This isn't really a problem, except during scrub, as you noted, where the turning radius might catch the fender edge.
You can cut the fender like many of us have, it's not bad, and if you take a bit to do it, can leave near factory looking results. (look at the linked pic in my sig; can you tell that the fender was cut? those are 265/75R16's....)
But, you'll be more likely to want to upgrade tire size too then. <img src="/forums/images/graemlins/smile.gif" alt="" />
Or, you can just go factory alloys. FYI, the factory size is 16x7, the width is measured from the inside edges of where the bead of the tire would grab; not the outer edges of the metal.
E.
Re: OEM 16x8 steel wheels and suitable replacements #613126 06/10/05 02:35 PM
matthew Offline
for 1...that is not a 16 x 8 wheel
how are you measuring that?
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: OEM 16x8 steel wheels and suitable replacements [Re: matthew] #613127 06/10/05 04:57 PM
rheteric Offline OP
Settle down boys..... They are 16x8! Isuzu made this style in an 8" width. When I get home I'll hold a ruler up to my extra and shoot a picture. Can we now return to original topic before I start doubting myself?
www.burnlounge.com/mp3me
'00 Rodeo LS 4x4; "K&N" cone filter; S/S Manik Front, Rear, & Nerf; 'Modest' sound system; 1.5" R'ooper lift, 265/70/16 Dunlop RVxt, Skyjacker Hydros, OEM LSD (sans G80 code)
Re: OEM 16x8 steel wheels and suitable replacements [Re: rheteric] #613128 06/10/05 05:37 PM
See my post here:
wheel width
It has this image in it:
That came from edmunds.com
Are you sure it's 8"? it just sounds really odd to us since we don't (haven't) seen that size before....
E.
EDIT - deleted the ridiculously long link
Re: OEM 16x8 steel wheels and suitable replacements #613129 06/10/05 10:18 PM
rheteric Offline OP
OK, don't castrate me, you guys are right, it is a 16x7. I guess I was being a little liberal with the flange measurement. Everything I read in the past made me think it was an 8 <img src="/forums/images/graemlins/confused.gif" alt="" />. I guess those were the OE alloy measurements I was looking at. Oh well. So, I won't be posting any pictures. Lesson learned: don't disagree with anything Matt says <img src="/forums/images/graemlins/lol.gif" alt="" />, and you too Elmo.
So I can forsee the wheel situation gets pretty ugly. Not only am I adding an inch in width, but the additional lack of backspacing in an aftermarket wheel is going cause some protrusion. Jeez, and now I've got 265s on a 7 inch rim, ugh <img src="/forums/images/graemlins/scared.gif" alt="" />. Hmmm, so help me out here; what I need is a 16x8 with as neutral offset as possible, or even better if slightly positive, right??? Anybody have any leads?
P.S.: I'll correct the 8s to 7s so as to not mislead anybody.
Re: OEM 16x8 steel wheels and suitable replacements [Re: rheteric] #613130 06/11/05 12:33 AM
Correct me if I'm wrong, but I believe the wheels have a negative offset, not positive...
Re: OEM 16x8 steel wheels and suitable replacements [Re: rheteric] #613131 06/11/05 07:18 AM
ProBMXer1313 Offline
My 265s are on 16x7 Isuzu alloy wheels.
What about 16x7.5 Isuzu Snowflake rims? I think those are neutral off-set.
Or get some 16x7 Isuzu factory alloy wheels with the same back spacing as your steelies
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: OEM 16x8 steel wheels and suitable replacements [Re: rheteric] #613132 06/11/05 02:06 PM
Don't sweat the 265's on Factory 7's. Everyone around here has done it at one time or another, without any major consequences.
Just be mindful that you need to run the right air pressure, so as not to balloon the tires and get uneven wear.
E.
Re: OEM 16x8 steel wheels and suitable replacements #613133 06/11/05 02:11 PM
Nope, Zu's do have a Positive offset.
Negative offset is when the mounting surface of the wheel is inboard of the wheel's centerline. Sometimes known as 'deep dish' wheels.
(Courtesy of Tire Rack)
E.
PHP: 7.4.33 Page Time: 9.665s Queries: 16 (0.003s) Memory: 0.6327 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-06-07 00:29:59 UTC
