OME shock/coil kit installation #61326 04/28/03 04:07 PM
I just ordered an OME coil/shock kit and should be getting it sometime this week. I believe that they are the 881 springs (not the HD).
My question is once installed what other things need to be checked to ensure proper operation once this mild lift is installed?
Also, what are some of your personal experiences with this suspension kit? How much lift did it yeild? How much larger of a tire could be installed? Any time and trouble saving tips for the install?
Thanks!
Re: OME shock/coil kit installation #61327 04/28/03 06:51 PM
If you own a 3rd Generation runner, you ought to read this...
If you type in 881 into the search, you ought to find some good info, probably from within the last week.
Re: OME shock/coil kit installation #61328 05/01/03 05:25 AM
Aurora Sandman Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by rockclimber:
<strong>I just ordered an OME coil/shock kit and should be getting it sometime this week. I believe that they are the 881 springs (not the HD).</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Are you getting front shocks/coils? If so, I found that installing the OME packers (spacers) was a necessity because the front would not otherwise be lifted enough. (As it is, my front is still lower, but equals out when I tow our tent trailer.
Mike Brown, 2001 4Runner, 4.88 gears, ARB rear locker, OME springs (heavy duty with two 5mm packers/spacers on each side in front, medium duty rear), OME comfort shocks all around, 33x10.5 BFG Mud Terrains, Slee Offroad sliders, & deck plate mod
PHP: 7.4.33 Page Time: 0.012s Queries: 14 (0.010s) Memory: 0.5884 MB (Peak: 0.6409 MB) Data Comp: Off Server Time: 2026-11-05 19:08:23 UTC
