screwed up Exaust #615125 06/15/05 11:22 PM
dailyDriver Offline OP
My 22Re has had a noticible exust leak from the rear end of the exaust manifold where it mates with the header since the day I bought it. The ticking sound is always loud when cold and almost un-noticible when hot. I figured it was the manifold/header gasket, and replaced it. I drove the truck with this new gasket for 10 minutes when it was cold to a mechanic because a stud on the head was stripped and it still leaked exaust. The mechanic says the brand new gasket (60$ at Toy dealer) is blown from the 10 min drive and the head must be pulled and machined to fix the stripped stud.
Is this guy full of it or what? <img src="/forums/images/graemlins/confused.gif" alt="" />
DailyDriver: '94 Xcab 4x4, 22RE, 139K miles, STOCK
Re: screwed up Exaust [Re: dailyDriver] #615126 06/15/05 11:36 PM
benmlee Offline
The head does not have to be pulled. If you pull the head, then you will need to replace more than just the exhaust gasket. The exhaust manifold is warped for sure, so needs to be machined. The thread can be repaired with a right angle drill and helicoil. It won't be as straight as taking the head out, but should be good enough. I did it with the head in without a right angle drill, because I was too cheap to buy a right angle drill, like this:
http://home.att.net/~benmlee/helical/helical.htm
The result was not great, but it worked ok. Make sure you use new locking nut or stage-8 fasteners. Otherwise, you will have to do it again soon.
Re: screwed up Exaust [Re: dailyDriver] #615127 06/16/05 11:14 AM
foxtrapper Offline
Another band-aid that can often work in this situation is to simply good permatex ultra-copper on the gasket and bolt it back up using the bolts and studs that are there.
Re: screwed up Exaust [Re: foxtrapper] #615128 06/16/05 12:38 PM
Just make sure you remove the exhaust manifold and put a straight edge on the surface that mates with the head. I had one that was really warped bad. I took it to the Napa store and he surface ground it back to flat for 5 bucks!! This was no ordinary grinding machine though. It was a vertical motor with the side of a grinding wheel protruding through a hole in the table. The wheel could be moved up and down to account for wear on the wheel. He just slid the manifold across the table repeatably until the surface of the manifold became flat again.
Cheap, easy fix, and done right.
Re: screwed up Exaust #615129 06/16/05 03:57 PM
I'll toss in my $.02 as well. Just went through this with my 86 22RE. Rebuilt motor and had an exhaust leak. Determined it was the manifold. Tried to tighten the bolts only to find out 4 were missing, 2 were stripped adn the others were holding fine (2 or 4 only the inside bolts). So, took it to a garage to have them helicoil the manifold and button it back up. Only thing they removed was the exhaust manifold, tapped the holes, helicoiled it and away I went. Now for the good part, this was done after putting about 50 to 60 miles on the motor in 20 to 45 minute intervals. So, I definitely wouldn't worry about that 10 miles. Main thing has already been stated, make sure the surfaces are square, install a new gasket ($45 from the dealer & $30 from parts store), and tap out the holes correctly. Be careful not to go to big and hit water jackets in the head.
Also, the garage I used stayed with 10mm, did not go to 7/16 as they didn't want to get to close to water jackets. Another user has had good luck with tapping to 7/16, main thing is find a garage or mechanic you trust. Mine has been fine now for over 300 miles (highway and offroad), no issues at all.
Good luck, and let us know how it turns out...
James
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.5980 MB (Peak: 0.6633 MB) Data Comp: Off Server Time: 2026-11-18 03:19:22 UTC
