Page 6 of 8 1 2 3 4 5 6 7 8
Re: The old Red Chili is dead... [Re: Red_Chili] #615720 07/06/05 03:13 PM
Red_Chili Offline OP
Toyota Section Staffer
Oh, and coming back from Buena Vista, in traffic, moving along at a pace that we shall merely refer to as 'respectable' (with accompanying intake roar and logging some passing lane time for once) through some significant South Park winds ahead of a cold front, I got above 19 mpg.
Mind you, I've gotten worse since the swap, bordering on what I got with a floored 22RE in third, but that there ain't nuttin' to complain of, with a flying brick.
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615721 07/06/05 07:54 PM
mt_goat Offline
Hey Bill, did you go with Downey headers?
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: The old Red Chili is dead... [Re: mt_goat] #615722 07/06/05 08:40 PM
Nope. Several reasons:
1) increased underhood heat, always unwelcome (esp. with a compressor there)
2) the stockers ain't bad at all
3) Downeys would prevent a behind-the-heads crossover, forcing a crossover behind the transfer case (waaaay back in my case, with a crawler, paralleling the fuel line <img src="/forums/images/graemlins/scared.gif" alt="" />) and forcing either dual converters or rearranging the whole exhaust
4) durability. Cast steel is hard to beat. They also have increased heat retention improving scavenging, though I doubt I'd notice. Redoing gaskets is something I'd like to avoid. So is Downey in general.
5) noise
6) more expense, like I needed that.
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615723 07/06/05 09:07 PM
Re: The old Red Chili is dead... [Re: Red_Chili] #615724 07/07/05 04:43 AM
mt_goat Offline
Does your exhaust stay on the passenger side after the stock 3.4 cross-over then?
Re: The old Red Chili is dead... [Re: mt_goat] #615725 07/08/05 02:09 AM
Yep. Very important design goal. Fuel and fuel lines and clutch slave cylinder (and honkin' welding cable feeding voltage from the rear dual batteries) on passenger side, exhaust on driver side. Oh, and reused the prior exhaust from the cat back.
-Bill
Re: The old Red Chili is dead... [Re: Red_Chili] #615726 07/08/05 02:54 AM
mt_goat Offline
I'm confused. Doesn't the stock 3.4 exhaust cross over to the passenger side?
Re: The old Red Chili is dead... [Re: mt_goat] #615727 07/08/05 03:08 AM
bkg Offline
Yes it does... now... curiosity is setting in. Pictures must be forthcoming...
Brian K. Gallus
Re: The old Red Chili is dead... [Re: bkg] #615728 07/08/05 06:39 AM
Seldom_Seen Offline
Sorry, I tried but it's so neatly tucked above the bell housing and it front of the firewall it's very difficult to see. I'll tell ya though, I held the cross over in my hand, at Mike's shop, it was an honor to hold such a fine piece of art.
Re: The old Red Chili is dead... [Re: Seldom_Seen] #615729 07/08/05 12:44 PM
mt_goat Offline
Oh, its a custom cross-over before the firewall?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6436 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-06-13 14:10:48 UTC
