Re: The old Red Chili is dead...
[Re: mt_goat]
#615740
02/06/06 05:08 PM
Toyota Section Staffer
All of it. Allows more airflow, therefore more cooling. He also removed the heater valve; coolant flows through the core full time. I was initially concerned about this but Mike has run this config before without issue. The Toy heater design directs outside air either over the core or bypasses it. No unwanted heat at all so far.
This solved an issue with heater hose routing, where a 180* turn in very tight quarters was required to keep the valve. Much cleaner without it.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5952 MB (Peak: 0.6348 MB) Data Comp: Off Server Time: 2026-06-07 05:46:23 UTCValid HTML 5 and Valid CSS
