Rating: 5
Page 8 of 14 1 2 … 6 7 8 9 10 … 13 14
Re: hubs [Re: ChrisB] #615845 04/05/09 07:00 PM
ChrisB Offline
My warn 60247's should be in tuesday <img src="/forums/images/graemlins/smile.gif" alt="" />.Then its wheeling time. Im so sick of this thing getting stuck because the 4x4 didnt work before.
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
Re: hubs [Re: ChrisB] #615846 04/08/09 04:14 AM
ChrisB Offline
They just arrived.They are already on the car.4 wheel drive actually works now.Will test them in the wash tomarow.What kind of grease should i put inside them? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Make it Break it
Re: hubs [Re: ChrisB] #615847 05/07/09 01:52 AM
2002_Sporty Offline
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: hubs [Re: 2002_Sporty] #615848 07/01/09 01:42 PM
budicexxx Offline
just wondering if the vacuum lines that go to the hubs is the line that comes out were the brake line comes out at the wheel well.
2001 sporty, tj rear springs with rav4 shocks, ford alloys machined centers with 30x9.5x15, front spacers. more upgrades to come.
Re: hubs [Re: budicexxx] #615849 07/07/09 10:20 PM
budicexxx Offline
just wondering what might be the problem is when i put my transfer case in 2High that the shaft from transfer case to the front diff. still turns...what might be my problem.
Re: hubs [Re: budicexxx] #615850 07/07/09 11:15 PM
budicexxx Offline
also just pulled off one front hub....is it normal to have play when i move the end of the shaft in the front rotor assenbly.
Re: hubs [Re: budicexxx] #615851 07/08/09 09:22 PM
Axe Man Offline OP
Kia Moderator Emeritus
Yes, and if you follow the vacuum line it goes to a fitting on the back of the hub.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: hubs [Re: budicexxx] #615852 07/08/09 09:27 PM
Axe Man Offline OP
With the transfer case in 2H the front driveshaft should be free and not turn. With the vehicle on the ground crawl underneath and try to turn the shaft. It may be hard to turn but it SHOULD turn. If it doesn't there's a chance that a hub is frozen in the engaged position.
Re: hubs [Re: budicexxx] #615853 07/08/09 09:28 PM
Axe Man Offline OP
There should be some play but I don't recall how much.
Re: hubs [Re: Axe Man] #615854 07/09/09 01:23 AM
budicexxx Offline
K so i just crawled under and the shaft only turns maybe quarter turn and then wants to turn the front diff. So this means that one or both of the hubs are stuck. Hmmmm
PHP: 7.4.33 Page Time: 0.035s Queries: 15 (0.032s) Memory: 0.6517 MB (Peak: 0.7590 MB) Data Comp: Off Server Time: 2026-10-21 17:14:16 UTC
