Rating: 5
Page 9 of 14 1 2 … 7 8 9 10 11 13 14
Re: hubs [Re: Axe Man] #615855 07/09/09 03:14 PM
budicexxx Offline
just wondering if the vacuum lines that go to the hubs is the line that comes out were the brake line comes out at the wheel well.
Yes, and if you follow the vacuum line it goes to a fitting on the back of the hub.
WEll im puzzeld. I check and the vacum lines that come out from the inner fender are blocked off Wish a rubber cap. So does this mean my hubs were modified to always be engaged.
2001 sporty, tj rear springs with rav4 shocks, ford alloys machined centers with 30x9.5x15, front spacers. more upgrades to come.
Re: hubs [Re: budicexxx] #615856 07/09/09 04:30 PM
Axe Man Offline OP
Kia Moderator Emeritus
It just dawned on me. You are in Canada. Kia Canada eliminated the vacuum hubs and installed Warn 61918 hubs as a campaign to fix the vacuum hub issues. It appears that one of your hubs is locked in. Try backing up about 10 feet a few times and see if it unlocks. If not you'll have to find out which hub won't unlock.
It is also possible that someone figured out how to permanently lock the vacuum hubs.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: hubs [Re: Axe Man] #615857 07/10/09 09:04 PM
budicexxx Offline
any suggestions once i find out what hub it is. Can i take apart and grease or clean is..ect.
Re: hubs [Re: budicexxx] #615858 07/10/09 11:23 PM
Axe Man Offline OP
Not sure. I have no direct experience with those type of hubs.
Re: hubs [Re: Axe Man] #615859 07/16/09 12:24 PM
budicexxx Offline
well i went and picked up some manual hubs yesterday. Installed last night and wow it solved my problem....No more noise in front end and my shaft is free.... smile
Re: hubs [Re: budicexxx] #615860 10/11/09 09:13 PM
Hydra747 Offline
Got a fairly new transfer case. Here's the deal:
I have an automatic transmission...When I shift IN or OUT of 4L while moving (in N or drive) faster than 5 miles per hr. I hear the gears grind! <img src="/forums/images/graemlins/confused.gif" alt="" />
I have to come to almost a complete stop before I can shift and only then it engages without incident.
What could be wrong?
Thanks,
Mikey
Re: hubs [Re: Hydra747] #615861 10/11/09 09:58 PM
Hydra747 Offline
Good Resource for general info of 4x4 part time, full time, AWD, 4x6, 4x8 ETC: <img src="/forums/images/graemlins/kewl.gif" alt="" />
web page
....And Lockers too....
Re: hubs [Re: Hydra747] #615862 10/11/09 11:38 PM
Axe Man Offline OP
Thanks,
Mikey
Nothing is wrong. The gears in the transfer case are sliding gears and have no syncros. You must be at a complete stop before shifting into or out of 4L.
Re: hubs [Re: Axe Man] #615863 10/11/09 11:45 PM
Hydra747 Offline
Thanks AXEMAN!
Boy do I feel like a DumbArse Now!
Not sure but my 98 did not do this....but maybe it did!
Thanks Mike! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: hubs [Re: Hydra747] #615864 12/21/09 03:22 AM
Kia_Bill Offline
Hey guys. Just like many of you, I hardly use the 4W on my 02 Sportage and after yesterday's 24" of snow I found out today that my 4W-drive is out. I have no clue how long it's been out but it's been some time I'd wager.
I'm thinking of getting the autolocking hubs from Warn to replace the stock ones. Couple of questions first though?
I get how manual locking works, but how does automatic work without the vac-hoses? Does the diff start turning the axles and the hubs just lock in step, or is it something else that I'm missing here?
Is there a warranty on the parts themselves or do I have to buy from Warn to get the warranty? I don't want these blowing up on me and forking out money for another set. I want them replaced if at all possible.
Thanks!
2002 Kia Sportage 4x4, stock.
Yes, I'm boring. I'm looking to change that.
PHP: 7.4.33 Page Time: 0.460s Queries: 15 (0.362s) Memory: 0.6539 MB (Peak: 0.7637 MB) Data Comp: Off Server Time: 2026-10-21 16:20:52 UTC
