Rating: 5
Page 14 of 14 1 2 … 12 13 14
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: ultim8m] #615905 04/21/15 01:35 AM
Dave Scott Offline
Ok, I know many years ago this question was answered, but at the time, I paid no attention because I either had manual hubs already, my Sportage wasn't a vacuum hub equipped model, or I had the straight axle already. Now I have a vacuum hub model and I just got a set of manual hubs. Gonna swap them tomorrow night and my big question is - how do I completely and permanently remove all traces of the vacuum hub equipment? I don't want it unplugged, I want it gone. Can I seal where the hose originally attached to the spindle? Can I plug the vacuum port from the intake (I'm assuming that's where it takes vacuum from)? Can I totally remove the actuator? Etc. I have worked on my old Sportage extensively, but, as mentioned, never experienced vacuum hubs. Thanks.
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: Dave Scott] #615906 05/24/15 05:38 PM
tspot Offline
Ok so Ill start by saying I have the non-vacuum style automatic locking hubs. They are the centrifugal style warn automatic locking hubs.
When I first got the sporty they would lock/unlock properly it seemed. after a while i noticed I would have to back up to get them to fully unlock and i never noticed that I had to do that before. I wasn't sure if this was how they were supposed to work. so I pulled the hub off and cleaned and re greased it. now just 2 days ago I think the hub is trying to lock itself in. but only seems to do this after I have reversed. So if i back out of a parking spot then start driving forward it seems normal. until about 40km/h or so then i can hear it whining like its trying to lock in. so if i slow back down at about 10km/h BANG it will pop out and stay out. until the next time I reverse. I pulled the hub off the wheel again and looked and I cant see any major evident problems. I put a little more grease on everything and took it for a drive and it made th whining noise but there was no bang this time. then it just went away. could it have been just not enough grease? I liked these hubs until now. for the past 3 months I have been at a job site with a lot of sand. so the hubs have been getting a workout in 4x4 all day until i leave the site.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6028 MB (Peak: 0.6513 MB) Data Comp: Off Server Time: 2026-10-22 12:16:05 UTC
