Rating: 1
Page 3 of 3 1 2 3
Re: 95 SR DOHC Timing Belt Change (pics) [Re: justice] #616122 09/02/05 03:05 PM
I recently did my 95 3.0L 24V. It is more similar to the 3.5L than to the older 3.0L I think. A couple of comments from my first crack at this not-too-small job:
1) When rotating the engine, do it from the crank. I first did it from a cam sprocket. Turns out it cannot turn then engine easily and I jumped a tooth on the belt. Which of course meant I had to do it all over again. <img src="/forums/images/graemlins/angry.gif" alt="" />
2) A tip from my B-I-L to help with the align the new was to mark the old belt and each of the sprockets with a white paint pen. Then transfer those marks to the new belt. Install the new so it aligns with the ones on the sprockets. I think this helped me in that you have to thread the whole belt in one direction to get to all the teeth right. I wasn't sure if I was dong it properly, but when the marks all lined up... Note that this does not replace the need to check the engine's markings as well.
3) Yes, those A/C bolts are a pain. There is one way back that I didn't know was there at first and was getting real PO's trying to find it.
4) For those unsure of doing, but equally sure of not wanting to shell out the $$$ to have it done, just take your time. Make sure you understand all that comes off as you do it and it will make more sense then going back together. FSM is helpful.
Re: 95 SR DOHC Timing Belt Change (pics) [Re: MontyMcV] #616123 09/05/05 06:42 PM
Great job Justice thanks for the pics. I am glad to learn something new on this lazy holiday. Thanks for documenting everything for us.
Re: 95 SR DOHC Timing Belt Change (pics) #616124 09/07/05 12:59 AM
sparkem Offline
Great post. Archive if not already. Nice tan too. Ha, I look like that too.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5982 MB (Peak: 0.6522 MB) Data Comp: Off Server Time: 2026-07-09 13:35:38 UTC
