removing rollbar #616322 06/19/05 05:22 PM
L
lilredrunner Offline OP
I'm needing more room to in the back of the runner to move a couch, and was wondering if anybody has removed the roolbar before. Does the bar need to be there to keep the body from twisting? Or is it safe to remove? Couch doesn't weigh much just way too big, plus the bar would be going right back on after moving a few sections.
Re: removing rollbar [Re: lilredrunner] #616323 06/19/05 05:50 PM
4Crawler Offline
It can be removed, no problem. 4 bolts on each bracket hold it in place.
Re: removing rollbar [Re: 4Crawler] #616324 06/19/05 06:23 PM
L
Thanks again for the help 4crawler
Re: removing rollbar [Re: 4Crawler] #616325 06/19/05 07:24 PM
G
Greg_Canada Offline
2 bolts on each bracket, actually.
Oh, and make sure to use some penetrating oil, i snapped off 3 bolts, and there was no way they were going to come out (the sheared off ends). I ended up drilling them out and putting in new nuts and bolts.
89 4Runner
Re: removing rollbar [Re: Greg_Canada] #616326 06/19/05 07:29 PM
4Crawler Offline
Ah, I guess there are only two. I could see two exposed and assumed there were two more under the carpet, but no, nothing under there. I was thinking they were like the All Pro roll bar kit I need to get installed, it uses 4 bolts per bracket.
PHP: 7.4.33 Page Time: 6.697s Queries: 15 (0.003s) Memory: 0.6077 MB (Peak: 0.6721 MB) Data Comp: Off Server Time: 2026-06-22 06:36:24 UTC
