Page 2 of 3 1 2 3
Re: Where are the parts? #617631 06/24/05 12:57 AM
H2O_MAN Offline
Your truck is rare - parts are super rare.
Not what I wanted to hear ... <img src="/forums/images/graemlins/angry.gif" alt="" />
Well, you have come to the right forum for help.
Aftermarket T-bars and rear leaf springs are available.
Bilstein shocks are available.
It will take some time and effort but you should be able to fix your truck up real nice.
I would stick with the OEM air-box and filter though...
Re: Where are the parts? [Re: H2O_MAN] #617632 06/24/05 01:56 AM
garym Offline
If you want my K&N you can have it for the price of shipping along with the oil and cleaner.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Where are the parts? [Re: adam] #617633 06/24/05 04:01 AM
You ready for this?
4.70
Yep, odd as heck I know, 4.70. 47 Ring Gear, 10 Pinion.
another 4.70 would make it easy to get running in 4x4, but I was also thinking of going a step up (or down -- however you want to call it) maybe to a 4.88 or 5.29 so I could put larger tires on the truck.
Re: Where are the parts? [Re: garym] #617634 06/24/05 04:04 AM
If they're that bad on T100s I'll just take your word for it and save the shipping $.
OEM filter can stay.
Re: Where are the parts? #617635 06/24/05 05:17 AM
4
4xGeek Offline
Amsoil air filters are arguably the best... Considerably beter than K&N, IMHO. If you do remove the airbox & use a conical, consider removing the lower fenderwell liners - makes a considerable difference in the underhood temps. And no, never any problems with splash (even living in PDX for the last few years).
Btw... You still haven't mentioned what motor you have - 2.4? 3.slow? Also, auto or manual?
ps - Yep, I'm baaaaaaack! <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Where are the parts? #617636 06/24/05 05:18 AM
Jake97T Offline
Garym:
Why do you want to get rid of your K&N, is it an intake system, ive been thinking about replacing my performance intake with a K&N system...
Re: Where are the parts? #617637 06/24/05 06:33 AM
surlynkid Offline
You ready for this?
4.70
very well known. trdjustin has them.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Where are the parts? [Re: 4xGeek] #617638 06/24/05 12:11 PM
H2O_MAN Offline
I have a slightly used Amsoil drop-in air filter for the 3.4L if anyone wants it... $20
Re: Where are the parts? [Re: Jake97T] #617639 06/24/05 03:31 PM
garym Offline
No, it is just the filter. After using it for a while found a lot of oil and oily dirt accumulating in the throttle body that I never had with the orig. air cleaner. Pulled the air tube and it too was coated with the oily crud. This was after using it per K&N instr. I did a lot of driving in the dust zones of E. OR. so thought it would be better than it was. Since I went back, the throttle body has stayed clean.
02 Camry LE
2008 Yaris
Re: Where are the parts? [Re: 4xGeek] #617640 06/25/05 02:32 PM
3.0L manual 4x4
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6350 MB (Peak: 0.7418 MB) Data Comp: Off Server Time: 2026-07-16 21:17:58 UTC
