oil sending unit ? #621260 07/01/05 03:33 PM
Roland2655 Offline OP
A few years ago I went to an aftermarket gage in my 85 4 runner. In that period of time the copper line has cracked twice. I'm starting to get paranoid that this is going to happen at an inopportune time. I converted the original dash cluster from idiot lights to the gage version with a tach. From what I can see the only conversion I needed to put this back to stock is get an oil sending unit for a gaged instrument cluster.
ridge runner
Re: oil sending unit ? [Re: Roland2655] #621261 07/01/05 03:37 PM
4Crawler Offline
Correct.
Re: oil sending unit ? [Re: 4Crawler] #621262 07/01/05 03:54 PM
thanks 4crawler. Any recommendations on where to get one other than the stealership.
ridge runner
Re: oil sending unit ? [Re: Roland2655] #621263 07/01/05 03:59 PM
4Crawler Offline
Re: oil sending unit ? [Re: 4Crawler] #621264 07/01/05 08:13 PM
87Toy4x4 Offline
did you hook up the sr5 gauges w/ the tach and not disconnect the original idiot light sender? if so your oil pressure gauge is probably broken b/c it was fully grounded. i thought the lines for the aftermarket mechanical oil pressure gauges were polyurethane tubing not copper. the copper lines are usually used for the aftermarket temp. gauge.
PHP: 7.4.33 Page Time: 1.846s Queries: 15 (0.003s) Memory: 0.6071 MB (Peak: 0.6712 MB) Data Comp: Off Server Time: 2026-06-23 15:36:12 UTC
