tire inflation with an A/C compressor ?
#622744
07/04/05 05:14 PM
has anybody used an A/C compressor to inflate tires or as an ARB compressor ? could anybody give me instructions on how to do it?
appreciate any help !!
Re: tire inflation with an A/C compressor ?
#622745
07/04/05 05:46 PM
Are you on a mission from god or something? I keep a portable air compressor in all of my vehicles, along with a plug kit and plenty of other tools, but have never needed to think about inflating a tire with an airconditioner compressor.
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
#622746
07/04/05 06:15 PM
I have not yet converted my AC compressor over to an air pump, but I am REALLY tempted.
Any body with good info?
[Re: NCBBA2358]
#622747
07/04/05 06:20 PM
jajaa !! nop, not at all... it's just that i have the compressor, not the rest needed for the a/c to work, and i've heard that is very simple way to have pressurize air, and a lot faster than a carry on type compressor.... cheers from Chile, for your independance day.. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
#622748
07/04/05 06:51 PM
Howdy Branko I have seen the instructions several times.. They are around here somewhere. Personally If I had a compressor I would have airconditioning! That along with a small 12v air pump would make my day! Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#622749
07/04/05 08:11 PM
Hola que tal !! bigJim, i had the same idea as you recomend, but here it doesn?t really get so hot...so the a/c is not so necesary.. geting ready for big celebrations today ?!!.... so here goes one <img src="/forums/images/graemlins/cheers.gif" alt="" /> for you!!!
Sunder, if i find the article y will tell you were it is...
#622750
07/04/05 08:23 PM
try www.rockcrawler.com in the tech section. should help some.
#622751
07/05/05 01:25 AM
Get on Jeepin.com or NAXJA or Pirate and search.
Search "York OBA" or "Sanden OBA"
$400-500 to set up an OBA system in most cases I've seen.
#622752
07/05/05 04:48 AM
I converted my AC to OBA... It worked pretty well but with an auto it was a pain to keep the engine at 2000 rpms to keep the air pressure up.. If you had a manual or at least a hand throttle it would work very well..
I still have the Compressor on my Jeep but I no longer use it.. I have been meaning to pull it out but I havent had time..
I switched to a VIAIR electric compressor and two storage tanks.. <img src="/forums/images/graemlins/smile.gif" alt="" />
#622753
07/05/05 07:09 AM
How was the volume of the engine pump compaired to the new electric pump?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6180 MB (Peak: 0.7231 MB) Data Comp: Off Server Time: 2026-06-19 14:49:46 UTCValid HTML 5 and Valid CSS
