Page 2 of 4 1 2 3 4
Re: 2.85 T-case gears don't fit. [Re: Kirk] #623582 07/07/05 07:24 PM
Frank has them in his Gen II, but he has an MT I'm pretty sure. I'd put up a post on the Outer Limits board. Good luck and keep us posted...
Re: 2.85 T-case gears don't fit. [Re: MontyMcV] #623583 07/07/05 09:18 PM
Kirk Offline OP
Outer Limits board?
KJ6GVJ
Re: 2.85 T-case gears don't fit. [Re: Kirk] #623584 07/07/05 09:27 PM
johnpsz Offline
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
91 Montero RS LWB w/ 320k miles before rebuild, 900 down and its still kicking!!!
Re: 2.85 T-case gears don't fit. [Re: johnpsz] #623585 07/07/05 09:43 PM
DougH Offline
Mitsubishi Forum Moderator
Do you have a 3.5 automatic? I thought they were suposed to fit the genII 3.0 automatics no problem. I know the 3.5 has a different model tranny and a different transfercase, but maybe the 24 valve engines had a different transmision combo as well.
I hope you get it worked out.
DougH
1995 SR - RIP
1993 RS - RIP
Re: 2.85 T-case gears don't fit. [Re: DougH] #623586 07/07/05 09:52 PM
He has an LS, so 3.0L.
I just emailed Frank (Mister Bishi) with a link to this thread. I'm sure he'll post up as soon as he can.
Re: 2.85 T-case gears don't fit. [Re: MontyMcV] #623587 07/07/05 10:12 PM
L
Lee N Offline
I just did some checking on the WINCAPS program and it appears that the 24 valve 3.0's must use the larger T-case from the 3.5's. The countershaft gear part number is the same as what's used on the 3.5 V6's. It's also different from the countershaft gear used on my 3.0 V6. Also, the chain is the same part number as that used on the 3.5's.
Kirk, I hate to say it, but I also think you're screwed.
It looks like the 2.85 gears will only fit the Gen II's through 1994 or those with the 12 valve 3.0's. Let me know if I can track down any part numbers for you.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: 2.85 T-case gears don't fit. [Re: Lee N] #623588 07/07/05 10:25 PM
justice Offline
I always wondered about this (differences in 24V VS 12V gen 2 3.0's drivetrain configurations)...I wonder if the 24V 3.0's also have the larger front diff assembly??
Re: 2.85 T-case gears don't fit. [Re: justice] #623589 07/07/05 10:30 PM
DougH Offline
Kirk I hope you can work this out, but if you cant pm me. It sucks when you get stuck with parts, I know I have been looking at my front 5.29 gearset with contempt for years now. <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: 2.85 T-case gears don't fit. [Re: justice] #623590 07/07/05 11:20 PM
It's been said that the MTs have the larger. Now I wonder if it's the MT 24V, or all 3.0 MTs?
Re: 2.85 T-case gears don't fit. [Re: MontyMcV] #623591 07/08/05 02:54 PM
L
Lee N Offline
Kirk's already installed the 5.29 gears for the Gen II's. These ONLY fit the small front diff, so I guess that confirms the fact that all 3.0/auto Gen II's used the small front diff.
I also confirmed this in WINCAPS. I compared the front carrier and the 3.0/auto's use the small diff, which is shared with the 2.6l trucks and the 2.6l Gen I's. The front carrier on the 3.0/MT trucks is shared with the 3.5l Gen II's, the 3.0l trucks, the 3.0l Gen 1's, the Sports, and the Gen III's.
Lee
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6472 MB (Peak: 0.7506 MB) Data Comp: Off Server Time: 2026-11-03 17:15:11 UTC
