Re: LSD slipping and e-brake usage [Re: NathanC] #623669 07/07/05 01:15 AM
Jamez Offline
Uhh.....I guess I'm insane <img src="/forums/images/graemlins/ignore.gif" alt="" /> My Mustang has a gasket so I guess I was just assuming everything does. I completely forgot about using plugs, but that makes a whole lot of sense right about now. So the front AND rear have drain AND fill plugs? Why didn't I just look instead of assuming and looking for something that apparently doesn't exist? Either that or maybe YOU guys are the insane ones <img src="/forums/images/graemlins/nana.gif" alt="" />
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: LSD slipping and e-brake usage [Re: Jamez] #623670 07/07/05 01:22 AM
W
wyleone Offline
The ft diff has a std cover but the rear is 3rd member style. Both in your 87 have drain and fill plugs. I did remove the ft cover at one point to extend the cap vent on the top of the ft cover (for water crossings). I used ultra grey silicone sealant to reseal the cover. There was no gasket there when I started either. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: LSD slipping and e-brake usage [Re: wyleone] #623671 07/07/05 01:54 AM
justice Offline
I always thought it would be cool to rig up a dual Parking brake setup on my old gen 1. Especially since it already had the cutout in the center console for the Left hand drive models..if the left rear was in the air just give the left p-brake a jerk...kinda a poor mans locker <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: LSD slipping and e-brake usage [Re: justice] #623672 07/07/05 02:20 AM
PHIL_ Offline
I was thinking the same thing with dual ebrakes, but then I got the auto, and the front LSD. Now I simply feather the pedal and throttle. Works awesome.
I don't use friction modifier either, but it sure barks going around turns. Well worth it off the trail though.
Re: LSD slipping and e-brake usage [Re: PHIL_] #623673 07/07/05 04:56 AM
DanWheeler Offline OP
Really?! the cutout is already there? I'm gonna have to take a look - that would be sweet.
The reason I asked about the front wheels not moving while the rears were spinning is because I wanted to know if a front LSD would really help me. Seems like if they aren't getting any power while the rears are spinning away it wouldn't do much good to have a rear LSD. Is something up with my transfer case or is that normal operation?
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: LSD slipping and e-brake usage [Re: DanWheeler] #623674 07/07/05 06:16 AM
52degrees Offline
Does your "wheel lock" light come on in 4wd?
When I bought mine, the chain was broken.
Clay
KG6VNX
Re: LSD slipping and e-brake usage [Re: 52degrees] #623675 07/07/05 07:23 AM
no, it doesn't but i'm pretty sure it's just a sensor or a light... i tried jacking up all 4 in the garage just dont make sure and they all moved.
1986 Montero 2.6l
Re: LSD slipping and e-brake usage [Re: DanWheeler] #623676 07/07/05 07:38 AM
i went and re-analyzed the video that was shot of me going up the hill and the front wheels are definitely spinning at the same speed both rear wheels were... i guess they just weren't doing much because of the steep angle making the front end much lighter and therefore pretty much useless. it's all about those rear 2 wheels when you're climbing steep loose stuff.
I need a real locker! i've been defeated! <img src="/forums/images/graemlins/lol.gif" alt="" />
1986 Montero 2.6l
Re: LSD slipping and e-brake usage [Re: DanWheeler] #623677 07/10/05 02:49 AM
Back in the Dark Ages (like 1965 or thereabouts) when the first dune buggies came out (the Meyers Manx), we used dual handbrakes on the veedub chassis's, since there were NO traction aids for beetles, or at least none we could afford. Worked like a charm, IF you could steer, shift, clutch, accel, AND yank a pair of ebrake handles. You only got one additional hand if you had a passenger, because he was holding both your beers in the other....
Re: LSD slipping and e-brake usage [Re: fasteddy] #623678 07/10/05 06:50 AM
That sounds pretty awesome and seems like it would be pretty easy to do with a junkyard lever. <img src="/forums/images/graemlins/notooth.gif" alt="" /> It would be a good interim solution until I can get a real locker. With this realization about the LSD I'm definitely not going to bother with a front LSD.
1986 Montero 2.6l
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6473 MB (Peak: 0.7523 MB) Data Comp: Off Server Time: 2026-11-15 19:26:27 UTC
