Electrical Help!!!! #624121 07/08/05 12:07 AM
mental Offline OP
Got an '87 Runner SR5, 22RE, W56 etc. While driving earlier today, the electric guages, signals (everything but the speedo) quit, the charge light came on and when the key is on but the truck's not running, none of the check engine, oil lights etc come on.
No time to give her the once over before work, but figured someone here had an easy answer to get back up and running.
Thanks in advance!
Mike
Re: Electrical Help!!!! [Re: mental] #624122 07/08/05 12:34 AM
Esquire812 Offline
Any kind of power with the key on? Door buzzer? Seat belt reminder? If everything died and no power to to anything then you prolly blew the 80A main fuse in the engine compartment fuse block. Double check both cab and engine fuse blocks for blown/burnt fuses and fusible links. Also...check your battery cables!! If they are corroded then they cant transmit power.
Speedometer is mechanical....nothing electrical about it. In fact it'll still work if coasting down the road minus the engine, battery...just about everything.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Electrical Help!!!! [Re: mental] #624123 07/08/05 02:07 AM
kewlynx Offline
Check your engine fuse (15a) in the driver's kick panel. You've got a ground shorting out. I had a chaffed wire where the starter is; it would short against the block in a left turn.
When did it fail? Nuther fellow had a bad turn signal switch taking it out for him.
Also see if your horn works; if not, check the 7.5a fuse for the haz/horn in the engine fusebox.
If you find either of these conditions, it's wire chasing time.
**ubi apis- ibi salus**
Re: Electrical Help!!!! [Re: kewlynx] #624124 07/08/05 06:36 PM
mental Offline OP
No worries there, the truck still runs, just lost power to the guage pack, signals etc. I'll have a run through the fuse panel and blocks. Let's hope it's nothing that requires a ton of searching...
Re: Electrical Help!!!! [Re: mental] #624125 07/18/05 09:53 PM
mental Offline OP
Alright, here's an update on the sitation, hope the extra details make it an obvious troubleshoot.
Engine fuse keeps blowing when truck is put into reverse. Obviously this seems to be a case of back up lights causing a short somewhere along the way. Is there a specific wire or ground I should be chasing?
I'll be starting with the engine ground and battery terminals and going from there...
Arrrrrrrrrrghhhhhhhh!
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6052 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-11-20 00:53:14 UTC
