Spent the last few weekends prepping this frame. Finally finished getting the rust and brackets off. Here it is upsidedown
Here's the drivetrain mocked up. Looking like a nice 48" front and rear driveshaft length. I am mounting up the t-cases using a front range offroad rear mounted crossmember so the drain plug is 1/2" from the bottom of the frame rail. flat skid plate... In order to do that I have to mount the engine a bit higher than I would like to.
Draglink should clear fine with the engine up so high.
Biggest reason engine is so high is the use of these stock camaro manifolds. They are wider than the frame rails. Did not want to build headers. We'll see if it's really top heavy as a result. Crank pulley and the entire block is above the framerails now. <img src="/forums/images/graemlins/scared.gif" alt="" />
![[Linked Image]](http://berisford.net/uploads/cpom/projectpup/9/4.jpg)
Here are the stock camaro engine mounts. I like this style because it is enclosed by metal. I decided to mount them vertical after welding a piece of 1/4" flat sheet to the seam in the frame c-channel. The mount will bolt to the square piece of metal at the top with some 3/8" grade 8 hardware then there is one mouting hole on the bottom of the mount through the frame. This will be a grade 8 3/8"x3.5" bolt with a frame sleeve. I'll add some gussets in the back afterwards.
engine mount bracket. 1/4" steel throughout.
This is the plan. The middle piece will be 3/8" and support pieces, as everything else, will be 1/4". Think it will hold? I'm concerned since the engine is mounted so high the torque will have such a long lever on the mount. Hope fully this week I can finish these and the t-case crossmember.
![[Linked Image]](http://berisford.net/uploads/cpom/projectpup/9/9.jpg)
