Through some research/advice I found my external pump must be mounted as low as possible to stay full of gas when powered off. I had to change my idea of using that little shelf for the pump.
Metal below is 1/8".
![[Linked Image]](http://berisford.net/uploads/cpom/projectpup/15/01.jpg)
This plate doesn't make contact with the frame rail or the 45-degree crossmember so I used some pieces of 1/4" angle as supports. Without these a hard hit on a rock will leave the pump taking the weight of the truck. Not sure if I'll add a piece from the crossmember to the gas tank skid support piece or not.
Below is after I added some studs. I wanted to make changing out the pump and filter something I wouldn't have to pull the cab to do. Now I should be able to just reach under with a little socket wrench and undo the hardware without looking at it. Space will be tight.
I'm curious about opinions when welding something flat to something beveled like this weld here. I used the wire to fill the gap between the two pieces. The flat piece is right up against the tube, but the tube has a rounded edge. Does this make a strong weld?
Another example of filling a gap with wire. Not sure if this is adviseable or not.
First pass underneath upsidedown. getting better. Power down to "3" and wire speed at 28.
![[Linked Image]](http://berisford.net/uploads/cpom/projectpup/15/06.jpg)
Second pass upsidedown, here's where I think I had it dialed in better. Power=2 WS=25. I found holding the gas nozzle in my left hand like a pen worked well.
My fuel rail has connections on the driver's side but tank is on passenger's. I tried running lines to driver's side but the crossmember area got confusing. This is what I settled on. 1" aluminum angle and self drilling/tapping screws.
Clerarance between lines and exhaust. Maybe I will wrap them.
[img]
http://berisford.net/uploads/cpom/projectpup/15/11.jpg[/img]
Here's where those studs I welded in come into play. I cut down the hardware so I think I should be able to reach under when the cab is on to change the filter. I used one of the stock fuel line disconnencts on the rear filter connection.
I wanted to use 3/8" send fuel line but the pump outlet is 5/16" I found a conveninent fix for that. The filter is Purolator F64728 and has a 5/16" inlet and 3/8" outlet. Strange huh? It is for early Ford thunderbirds. The cardboard is temporary until I find some foam padding.
[img]
http://berisford.net/uploads/cpom/projectpup/15/12.jpg[/img]
[img]
http://berisford.net/uploads/cpom/projectpup/15/13.jpg[/img]
Gas tank hookups.
[img]
http://berisford.net/uploads/cpom/projectpup/15/14.jpg[/img]
