PCV Valve.... Where is it located.on the V6 3.0?
#624588
07/08/05 09:44 PM
PCV Valve.... Where is it located.on the V6 3.0? It is running rough and I am swapping out the fuel filter and plugs this evening. I want to check and clean the pcv valve if I can find it? Thanks in advance, Kevin
... who just rebuilt me rearend and dropped in a true-trac. all good.
Re: PCV Valve.... Where is it located.on the V6 3.0?
[Re: WashingtonKevin]
#624589
07/08/05 09:59 PM
Passenger side about mid-way on the valve cover(under the intake). You will need a long pair of needle nose plyers. I purchased a new hose as well as my hose was brittle and fell to pieces when I took it off. The hardest part is getting the grommet back in with the PCV valve(you will need a new one of these also, since it will be hard as a rock). Put a little greese on the PCV valve and it should go......It's a pain and takes some time.
#624590
07/09/05 01:39 AM
Hi Kevin, we also have a 93 FSM sticky'd here for reference; includes 22RE and 3.0 information. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5924 MB (Peak: 0.6457 MB) Data Comp: Off Server Time: 2026-10-25 02:42:51 UTCValid HTML 5 and Valid CSS
