Is this normal????? (About the volt meter gauge) #624751 07/09/05 05:24 AM
Tygger Offline OP
I just noticed today that everytime I floor my Rodeo, the battery volt meter drops from about 14 to 11-12. Is it normal for it to dip down????? Or is something wrong?
1997 Isuzu Rodeo S 4WD
Re: Is this normal????? (About the volt meter gauge) [Re: Tygger] #624752 07/09/05 06:06 AM
PassportMike Offline
Yup, it's normal. I'm currently on my fourth alternator and they've all done that. I think I read somewhere else on this forum that one of the leads into the alternator tells it when engine vacuum is low (engine revving). The alt then somehow produces less voltage, causing less resistance on the engine.
'97 Passport
Re: Is this normal????? (About the volt meter gauge) [Re: Tygger] #624753 07/09/05 11:52 AM
Canucklehead Offline
This is discussed in the owners manual (if you have it).
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Is this normal????? (About the volt meter gauge) [Re: Canucklehead] #624754 07/14/05 05:26 AM
E
EricW Offline
I have the same problem with my '96. At first I thought it was an alt. problem but I noticed that the only time that the voltage would drop was when the accelerater pedal was pressed. I was able to find that by turning the park lights or headlights on it would stop this from happening. <img src="/forums/images/graemlins/zombie.gif" alt="" />
1996 Trooper S 3.2 5sp OME919/ProComp ES9000
BFG Dueler A/T REVO 265/75R16 w/Snowflakes
1991 Trooper 2.6 5sp 33x12.5 BFG T/A
Re: Is this normal????? (About the volt meter gauge) [Re: Canucklehead] #624755 07/14/05 08:33 AM
trooperbc Offline
where in the owners' manual. what does yours say?
thanks
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: Is this normal????? (About the volt meter gauge) [Re: trooperbc] #624756 07/14/05 11:32 AM
thanks
From page 2-8 of the 1997 (1996 as well?) Rodeo Owner's Manual:
"When the accelerator pedal is pressed, when driving or with the engine idling, the voltmeter will drop into the low voltage range. This results from a changeover in alternator voltage control designed for fuel economy improvement. However, the voltmeter needle will not drop if the head lights are turned on or if the engine coolant temperature remains low."
Steve
Re: Is this normal????? (About the volt meter gauge) [Re: Canucklehead] #624757 07/14/05 05:12 PM
Tygger Offline OP
Didn't think something like that would be in the owner's manual, but thanks anyway. Glad that its normal...
If I accelerate moderately, the needle doesn't drop. It only drops when I punch the pedal to the floor.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6128 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-06-17 16:08:10 UTC
