Re: Engine removal going slowly (few questions) [Re: johnpsz] #625370 08/15/05 11:13 PM
TobyB Offline
try www.mr-auto-parts.com...
they had motor mounts for the TAX on what the dealer wanted,
the water pump,
and I think the timing pulley, too.
also www.rockauto.com, but their shipping is expensive...
hth,
Toby
'89 V6 4dr- '4- Doris'
Re: Engine removal going slowly (few questions) [Re: johnpsz] #625371 08/16/05 12:20 AM
DougH Offline
Mitsubishi Forum Moderator
Well I started on the task of pulling my motor this past weekend, this is going to take forever <img src="/forums/images/graemlins/scared.gif" alt="" />
I spent 3 hours on Friday evening after work, and another 3 or so hours yesterday, and I still have a lot left to do.
Why does Mitsu use so many different size bolts? Most of that time was documenting what bolt went where... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I have all the wireing disconected, all the fluids drained, all the brackets from front of the motor are off (it's down to the timing covers), and the starter is out. That's it after 6 hours.. <img src="/forums/images/graemlins/angry.gif" alt="" />
All I have left is Exhaust, Fuel lines, throttle cable, tranny conections..
Ok on to my questions:
The truck was not in a running state when I started this so I could not start it to release fuel pressure, is there another way to do it or am I just going to make a mess?
What is the best order to remove the exhaust? I know I need to pull the Y-pipe, because it crosses directly under where I need to get at to take the torque converter bolts off from. I just didn't know of the best way to start. Should I start by discontecting them from the manifolds first or at the intermediate pipe?
And last but not least, do you need to pull the drive shaft to get to the drivers side motor mounts? The book says so but I haven't really looked at it yet, and figured when I was under there messing with the tranny I would just pull it then if need be.
You need to pull the pipe that connects to the driver side manifold, but you can leave the portion that connects to the passenger side manifold in place. I assume that is what you ment by the y pipe. Disconnect the pass side pipe that bolts to the manifold... then the connection at the Y that is under the tranny. Pull the exhaust back enough that you can then pull the pipe that goes up to the driver side manifold. That is the order I use at least. Install in reverse order. <img src="/forums/images/graemlins/smile.gif" alt="" />
Pulling the driveshaft is up to you. I dont, but it really makes for a tight squeeze with your hands. Coming out it is ok, but it makes it a pain in the arse to get the motor mount bolts back in later on. The tcase might leak a little if you pull it. Make sure to scribe it so you can put it back on the same way.
There wont be any major pressure in the fuel line. Just use a rag to get the stuff that spills out. No smoking.
DougH
1995 SR - RIP
1993 RS - RIP
Re: Engine removal going slowly (few questions) [Re: TobyB] #625372 08/16/05 09:55 PM
johnpsz Offline OP
the water pump,
hth,
Toby
Thanks, but I was hoping to find something with part numbers for OEM stuff, or at least something where I can get an idea of exactly what I am looking for. Those sites have a couple of the parts I need, but also show more then one for the same application, so how do I know what the correct one is?
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
91 Montero RS LWB w/ 320k miles before rebuild, 900 down and its still kicking!!!
Re: Engine removal going slowly (few questions) [Re: johnpsz] #625373 08/16/05 10:35 PM
DougH Offline
What parts do you need, pm me a VIN and a list of parts I will see what I can do. <img src="/forums/images/graemlins/smile.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: Engine removal going slowly (few questions) [Re: DougH] #625374 08/17/05 02:22 PM
johnpsz Offline OP
Doug, Thanks!
PM sent!!!
The parts I need are listed above as well.
Again, Thanks for the help,
John
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6160 MB (Peak: 0.6996 MB) Data Comp: Off Server Time: 2026-06-10 04:23:49 UTC
