Page 3 of 4 1 2 3 4
Re: Largest tire on 88-91 Trooper? [Re: 1jackleg] #625764 07/12/05 09:25 PM
ProBMXer1313 Offline
Ya, putting a tire on a narrower rim then recommended will really wear out the center of the tire faster, but maybe you can counteract that buy using low air pressure so you have even tread contact.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: Largest tire on 88-91 Trooper? [Re: 1jackleg] #625765 07/12/05 09:27 PM
marcucci Offline OP
However, I would think that the buldging side wall effect would change the handling of the truck. Also, I would think that your wear pattern would be off and you would get fewer miles on the the tires.
Handling I mind. Wear, I do not. As it is my Kumho Venture MTs (pretty soft, IMHO) have lasted more than 50k miles. The Wrangler AT/S's that I had on before these lasted more than 50k miles.
Wear, well, I don't want to pay for contact patch/rubber I'm not using. Anyone have an idea of how distorted it would be? I would think that with that much sidewall the contact patch would still stay reasonably flat.
It might be worth a trip to the tire store and ask them to mount one up and test fit it.
Thanks again, everyone, for all the good info.
Re: Largest tire on 88-91 Trooper? [Re: marcucci] #625766 07/12/05 09:32 PM
1
1jackleg Offline
You could get an idea by getting the actual section width and height of the tire you are wanting to purchase. Then use the rim width with a centerline from the section width to the centerline of the rim width the length of the tire height. Am I coming through clear. I feel as though it is not. HTH - JL
I ain't real bright...
1990 Trooper LS, V6, Auto, 4door
132,000 miles 11/26/09
Re: Largest tire on 88-91 Trooper? [Re: 1jackleg] #625767 07/12/05 09:58 PM
1
1jackleg Offline
according to messurements (not under load), my tires are deflecting 5? from the mounting surface.
Your sittuation, using interco specs for a 33x12.5 would be deflecting 10? beyond mounting surface.
Like this \ / How much is too much is the question.
Then you would have to lower pressure to compensate for wear pattern. This will exaggerate this deflection due to squatting of the tire with lower pressure. Rolling resistance goes up as does heat. Down goes tire life and fuel milage.
I'm really not trying to talk you out of it <img src="/forums/images/graemlins/lol.gif" alt="" />. I'm sure it's been done. FWIW - JL <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Largest tire on 88-91 Trooper? [Re: 1jackleg] #625768 07/12/05 10:02 PM
marcucci Offline OP
Thanks. My 10.5's seem OK on my 7" rims now, but that's on the low side of what Kumho (and most other mfrs) recommend.
I am reluctant to go the 33x 10.5 route due to more height and not more track (stability). Probably would be OK, though.
I'm thinking with the 32x11.5, I'm gaining .5" in height and spreading it another .75" or so. Should only deform it slightly?
Re: Largest tire on 88-91 Trooper? [Re: marcucci] #625769 07/12/05 10:11 PM
1
1jackleg Offline
I used a 7.5 rim in the above reply for your application.
Same issues as above only less dramatic. according to Interco, you are adding .75" in height and spreading .5" - JL
EDIT to add - I, personally (and I know your not asking) would d0 the 33x10.5 and enoy the extra height. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Largest tire on 88-91 Trooper? [Re: marcucci] #625770 07/12/05 11:27 PM
pucci Offline
I'm also running 33x10.5, no lift, 15x7 OE alloys. no rub, no problems. I've tried to cross it up but still couldn't get any contact that I noticed.
handling is good - expected it to be really obviously bad when I made the change. I'd cruise curves without worry(no front swaybar either), felt very stable. keeping the IFS height unmolested rewards you with fine & dandy handling regardless of tire size(to a limit i suppose)
theres an old thread on Pirate showing a dude running 33x12.5 on the OE 15x6 alloys, stock height. he claimed no problems at all & had plenty of wheeling pics.
for all out trail use I'd wager 34x9.5 swampers will be a good fit on neutral 6" rims without a lift.
2.6 Trooper
2.0 Impulse Turbo
Re: Largest tire on 88-91 Trooper? [Re: pucci] #625771 07/13/05 12:30 AM
paulevans76 Offline
with a little cutting and smashing you can fit 35x12.50's on her. you know you want to <img src="/forums/images/graemlins/evil.gif" alt="" />
88 Troop - Posing yard art
Re: Largest tire on 88-91 Trooper? [Re: marcucci] #625772 07/13/05 12:34 AM
Richard Saylor Offline
Richard: What BS did those wheels have?
I have no idea. If you want, I'll get out there and take one off and measure it the first chance I get.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Largest tire on 88-91 Trooper? [Re: Richard Saylor] #625773 07/13/05 01:47 AM
barak Offline
I'll be throwing some new shoes on my trooper soon , its a first gen with a 3" suspension lift , and I am going with 33x12.5 on an 8 inch rim.I might go with a 10" rim if they have the same price and they fit ok.Getting 4 new tires and rims , installed and balanced for 1100 , which is pretty good considering everywhere else around here wants 1100 just for 4 31" tires. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6416 MB (Peak: 0.7515 MB) Data Comp: Off Server Time: 2026-06-21 17:50:09 UTC
