ABS Sensor on '00 Rodeo #625909 07/13/05 12:31 AM
0
00328 Offline OP
Okay, I asked a question about my serpentine belt and got exactly the help I needed, Thanks.
Now I have a question about the ABS sensor on a '00 V6 Rodeo.
The sensor light keeps going on and off and the brakes feel just fine. The dealer said it's probably just the sensor as they tend to be problematic. My question is does anyone know where the sensor is located on this model? Figure it can't be too hard to replace, if I can just find it.
Re: ABS Sensor on '00 Rodeo [Re: 00328] #625910 07/13/05 01:00 AM
ProBMXer1313 Offline
You either have 3 or 4 ABS sensors. My 98 has two at the front, one on the back side of each rotor, you'll see a wire going to it. Then one on the back in the top middle of the diff but for a 2000 it may have one sensor at each rear wheel instead of in the diff.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: ABS Sensor on '00 Rodeo [Re: ProBMXer1313] #625911 07/13/05 03:55 AM
0
00328 Offline OP
Well damn, that kind of complicates things a little.
Re: ABS Sensor on '00 Rodeo [Re: 00328] #625912 07/13/05 05:02 AM
Richard Saylor Offline
Get the code pulled. It should tell you which one it is.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: ABS Sensor on '00 Rodeo [Re: 00328] #625913 07/13/05 12:33 PM
LetsRodeo Offline
This might work on 2000 models.
Here's a link to the Diagnostic Truoble Codes (DTC) you can access with out a scanner.
For my 99 Rodeo the standard OBD II scanner couldn't read the ABS codes. You have to have the factory scan tool.
ABS DTC Document
If you want something done right do it yourself two or three times!
LetsRodeo
1999 Isuzu Rodeo LS 4WD
3" CPL, 3" BL
LT265/75 16 TOYO Open Country AT
ShrockWorks Rock Sliders
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6047 MB (Peak: 0.6689 MB) Data Comp: Off Server Time: 2026-05-29 20:28:14 UTC
