Electrical diagnosis #626996 07/15/05 08:37 PM
2
2timer Offline OP
My drivers side rear tailights along with the liscense plates lights are out. The tester I have works on the battery terminal but can not get a positive test from the passanger rear lights (which work). I am grounding to the rear hitch which is connected to a a pretty rusty frame. Is the rust my problem?
Re: Electrical diagnosis [Re: 2timer] #626997 07/15/05 09:18 PM
FrankR Offline
It could very well be the problem. Why don't you try testing from the (+) of the bulb socket to an inside-the-truck screw into the body for (-) and see if you have 12vdc. Or, you could try testing continuity from the bulb socket frame to the chassis (or body) and see if you have a good connection.
If the light control relay was the problem you wouldn't have a tail light on the other side either.
Frank
Re: Electrical diagnosis [Re: FrankR] #626998 07/16/05 12:56 AM
Take out the passenger side rear lamp assembly, and you'll find the connector for the drivers side light harness inside the hole. Check that, too. Plenty of good grounds when you take the housing out...
Re: Electrical diagnosis [Re: fasteddy] #626999 07/16/05 03:41 PM
52degrees Offline
And one other thing, put the DVOM away. It's no good for checking power/grounds on unloaded circuits. Use a test lamp for this kind of diagnosis. It's much more accurate.
Clay
KG6VNX
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6016 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-11-14 18:47:56 UTC
