Page 1 of 6 1 2 3 4 5 6
ball joint recall #627270 07/16/05 01:28 PM
shovelhead Offline OP
has anyone recieved any notification about this recall
With enough time and enough money ya can fix anything
Re: ball joint recall [Re: shovelhead] #627271 07/16/05 03:01 PM
little_joe Offline
Former Admin
Not yet..........
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: ball joint recall [Re: little_joe] #627272 07/16/05 03:31 PM
I found this on Toyota's site:
http://www.toyotaownersonline.com/news/articles.php?id=10
Service Campaign Set for Some '01-'04 Truck and SUV Models
Publication Date: 05/31/2005
On certain 2001 û 2002 Model Year 4Runner, 2001 û 2004 Model Year Tacoma 4WD and PreRunner, and 2002 û 2004 Model Year Sequoia and Tundra vehicles, there is a possibility that the Front Suspension Lower Ball Joint may experience excessive wear and looseness causing increased steering effort, reduced vehicle self-centering, and noise in the front suspension. If the vehicle is continued to be operated in this condition, in extreme cases, the lower ball joint may separate from the knuckle causing a loss of vehicle steering control.
This new Special Service Campaign (SSC) will be launched in late June, 2005. Owners of the involved vehicles will receive a SSC notification by first class mail beginning in late June, 2005. The owner notification will be completed around December, 2005. Toyota dealers will replace the left and right Front Suspension Lower Ball Joint at NO CHARGE to the vehicle owners.
Re: ball joint recall [Re: shovelhead] #627273 07/16/05 06:40 PM
I've allready replaced mine. When I put my truck back together I decided to go ahead and replace the ball joints. The mechanic told me it was only the lower ball joints that were going to be recalled.
Re: ball joint recall #627274 07/17/05 09:35 PM
my upper ball joints seem to be greasy on the outside, like if it got torn. Or is this like normal?
Re: ball joint recall #627275 07/17/05 10:27 PM
More than likely its normal.
Re: ball joint recall #627276 07/18/05 02:36 PM
VanillaGorilla Offline
OK here is a question someone may know ... if you bought the 'yota used, or if you have moved since buying it, how does Toyota know your contact info?
Hang on, we're goin for a ride!
Re: ball joint recall [Re: VanillaGorilla] #627277 07/20/05 12:12 AM
mater Offline
They get the mailing info from where you purchase your tags and registration. or that is what i have been told
02' TRD Double Cab Taco 3.4 Auto SR-5
Re: ball joint recall [Re: VanillaGorilla] #627278 07/20/05 08:12 AM
kewlynx Offline
Contact the Toyota Regional Center where you are now, with your VIN, and where you bought the vehicle from, so they can get you in the database. We went thru this with the roomie's Corolla. Her DFW maintenance records had to be transferred to our regional area here.
The mailout campaign is supposed to run thru December.
**ubi apis- ibi salus**
Re: ball joint recall [Re: kewlynx] #627279 07/24/05 02:01 AM
kewlynx Offline
Bump for sticky, please. <img src="/forums/images/graemlins/cheers.gif" alt="" />
For you Taco/Tundra folks, the recall is sticky'd right now in the Runner section, FYI; some links available to follow.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6296 MB (Peak: 0.7515 MB) Data Comp: Off Server Time: 2026-10-22 07:01:37 UTC
