electric fuel pump
#627819
07/18/05 08:12 AM
I just picked up a carter electric fuel pump to swap out for my mechanical pump but am wondering what the best way to wire the fuel pump shut off is? should I get a oil pressure safty switch or wire in a toggle switch of sorts? thanks in advance <img src="/forums/images/graemlins/cheers.gif" alt="" />
erick
85 Pickup 33s, lift, EB cam, header, exhaust...
Re: electric fuel pump
[Re: dewmtndew]
#627820
07/18/05 01:23 PM
Toyota Moderator
As safe as possible given the consequences of a ruptured gas line and it not shutting down after a crash...
Suggest based on technicques used by manufacturers the following..
Use the oil pressure switch to keep it running under normal mode..
and to cover the situation when starting the engine but no oil pressure yet, use the start position of your ignition switch as an override to make it run while starting..
2000 4Runner,V6,Auto,31's, Sliders, Skids, On-Board Air, Air Shocks Related Interests: Welding, Ham Radio, Road Tripping (Blue Highways), High End Video/Audio Systems
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5869 MB (Peak: 0.6350 MB) Data Comp: Off Server Time: 2026-06-07 01:01:42 UTCValid HTML 5 and Valid CSS
